Another Lowering Question, but different?
I have a 02 C32, and i wanted to upgrade the springs only (keeping cost down), since I just want to fill some gap and have better handling (don't need a go-kart ride!!).... however, the complication is, I have the extended warranty!! There is no point for me to change to aftermarket springs to void my $2k extended warranty!
So in order to keep the warranty intact, I am thinking (maybe i am silly), if I change my spring to the C55 spring (stiffer?) and also change to the thinnest spring pad, do you think I can achieve my goal while keeping warranty intact? Or am I just burning money by getting nothing out of it?
Thanks for the help guys!!
I don't know about the C55 springs idea. I'm not sure how the C32 shocks will work with the stiffer C55 springs. In addition, the spring pads are only on the rear so you will not be helping the large front gap.
FYI, IANA Mechanic.
FYI, IANA Mechanic.
SO.. the first dealer.. MB of San Diego.. (This Dealer is the worst I have ever encountered on any car) said they wouldn't cover the bushings because I had aftermarket springs.. TOTAL BS!!!
The next dealer, MB of Escondido stated that the bushing failure had nothing to do with the springs, it was a known issue with the original bushings.. YEAH NO *****.. thanks for nothing MB OF SD read your TSB's morons!!
The aftermarket springs will NOT void your warranty. Any reputable service advisor/manager should know this.
FYI.. I still have my Brabus springs.. no problems with the extended warranty whatsoever with the new dealer I use now.
I would:
#1. check to see if you car has the original bushings/arms etc. If so get them replaced right away.. If you hear a squeeking sound going over speed bumps etc..
#2. go get some aftermarket springs installed!! I like my brabus.. nice ride.. great height..
Good luck!
Good luck!
So i will talk to my dealer first..and see if they will install them for me.......
theres high res pics too if u want to see it supersize.
dealer installed to keep all warranty issues intact. you should do same.
anup
