Changed the plugs and wires...BIG difference!
Old May 12, 2006 | 01:58 AM
  #51
Eurocharged Rick's Avatar
SPONSOR
Originally Posted by psk145
I thought I read somewhere that the blower is always engaged after 1500 rpm
nope, the blower being engaged depends on load, not rpm....if it was rpm dependent, then it would be engaged at highway speeds all the time, which would kill gas mileage...
Old May 12, 2006 | 12:22 PM
  #52
psk145's Avatar
2006 E55
I think this is what I was referring to, but Im still not sure of it
https://mbworld.org/forums/c32-amg-c55-amg-w203/76613-3000rpm-supercharger-cut-limit.html
I had a supercharger on my E36 M3 and I had no significant loss of fuel consumption. When the car was driven lightly, the compressed air would be bypassed and injectors wouldnt dump more gas. im not sure how the C32 works though.
Old May 12, 2006 | 12:54 PM
  #53
SPONSOR
https://mbworld.org/forums/showthread.php?t=76613
well, if the conclusion in that post is true, then that means that there is no way to get really good gas mileage out of the C32 unless you drive at 60mph or below(or whenever you reach 2900rpms)....that sucks!
i am going to test this out today, very interesting...
Old May 12, 2006 | 01:02 PM
  #54
psk145's Avatar
2006 E55
its it possible that its similar to my old setup where the SC is fully engaged, but the extra air is bypassed and recirculated?
Old May 12, 2006 | 04:04 PM
  #55
Zeppelin's Avatar
C32
Originally Posted by cntlaw
Seriously need advice as what spark plug model to upgrade spark plugs for
C55. Actual user experience needed. thanks
Why change the plugs on a new C55? Not going to see any difference
Old May 12, 2006 | 04:07 PM
  #56
Zeppelin's Avatar
C32
The blower is engaged at 2900rpms or so to let the engine breath better. Unhook your supercharger clutch and go for a test drive and you will see what I mean. The motor will fall flat on its face above 3000rpm. There is very little path for the air to flow through the SC when not turning.
Old May 12, 2006 | 05:29 PM
  #57
Vomit's Avatar
2002 C32 Black/Charcoal
I really wish that the C32 had 10-15% taller final gearing. It would allow cruising in the mid-70s without S/C engagement, and would allow the car to finish the 1/4 mile in 3rd gear (stock, the 3-4 shift is about 103 MPH), not to mention easier launches and potentially a 200 MPH top speed (with substantial engine mods, of course). If anyone knows a way to do this without spending a fortune, I would like to hear it.
Old May 13, 2006 | 01:27 AM
  #58
SPONSOR
change the rear end gear...but your car would be a lot slower off the line without a lot more power...and you would have to figure out how to recalibrate the speedometer....other than that, i don't think anything else would have to be changed, but with everything being electronic on this car, you never know what it could mess up...
Old May 13, 2006 | 11:32 AM
  #59
Vomit's Avatar
I really don't think that it would be much slower off the line, as there is no way that I can use full throttle in first gear as it is without smoking tires (from a stop, or from a 20MPH roll, it doesn't matter. . . the net result is no traction). I guess that 2nd and 3rd gear acceleration would be somewhat slower, however. I still think that the net result in the 1/4 would be a faster E.T.. Especially for modded cars, the fact that you end up doing the last part of the 1/4 in the bottom of 4th gear is not good.
Old May 15, 2006 | 02:04 PM
  #60
m3_eater's Avatar
An LSD helps tremendously in this regard. Sure, the wheels are still spinning - but in a much more linear/controllable manner
Old May 17, 2006 | 04:25 AM
  #61
cntlaw's Avatar
C55AMG W203; 330i E90
28000km now. Still no need to change
Old May 17, 2006 | 09:50 AM
  #62
Zeppelin's Avatar
C32
Nope - There good for 150000km
Old May 17, 2006 | 10:14 PM
  #63
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
well I got my wires in form Alamomotorsports. I did the 2 passenger side first and its do able but its not easy. make sure you have different size extension. pulling the old spark plug wire was a biach. i didnt have to take the air box off. if you do replace the spark plug wire make sure you push them in all the way and slightly tug on the wire to make sure its on. I will take some pix but I'm doing this real slow cuz my allergies are real bad so I can only work on the garrage for a shot time.
thing to remember
1. dont work on the car if its hot or warm, let the car cool down.
2. installing the new spark plug make sure you hand tight it first, dont use a rachet or you might strip the aluminum head. $$$$ to fix.
3. make sure the new wires are on tight.
I will post some pix soon
Old May 20, 2006 | 11:48 AM
  #64
pugguy2001's Avatar
2016 C63s AMG
I know I am in the wrong message board but when I searched for Denso Iridium plugs this came up. I have a 2005 C230ss. I have the Kleeman boost kit w/k-box and soom to come the kleeman header with the ECU upgrade. Nobody has recomended to upgrade my plugs but after read this thread I feel it can possible be to my advantage. the denso website doesnt list 2005 c230 plugs, but it does fro 2004. It list IK20. Does any one any advice for me?
Old May 20, 2006 | 02:08 PM
  #65
rlee02135's Avatar
2004 C32 ///AMG
try the 04 plugs
04 and 05 cars have the same engine.
Old May 20, 2006 | 05:41 PM
  #66
pugguy2001's Avatar
2016 C63s AMG
Originally Posted by rlee02135
try the 04 plugs
Do you know of any one that switched to these plugs. What were their thoughts?
Old May 21, 2006 | 12:28 AM
  #67
Vomit's Avatar
thing to remember
Very true on the removal of the wires. Major PITA.
I feel your pain from the allergies, bro. The pollen this year has sucked, and there is nothing worse than doing an aggravating job while the roof of your mouth feels like it has poison oak and you are sneezing every ten seconds. I can load myself up with every OTC and prescription allergy drug, and all that changes is that I sneeze every 15 seconds.
So, did you finally finish?
Old May 21, 2006 | 01:08 AM
  #68
Trekman's Avatar
YES I DID!!!!! car is more responsive and took it on the freeway 4th gear my ESP light was flashing as I hit red line car got kick on high RPM's.
Here is the link to my blog where I took some pix of the job enjoy.
http://mbpowered.blogspot.com/
Old May 21, 2006 | 07:39 AM
  #69
cntlaw's Avatar
tks
my friend told me never change to other spark plugs than the stock spec for my C55. i think he has a point there, but not sure why?
Old May 23, 2006 | 08:31 PM
  #70
Benzinsider's Avatar
02 C32, 05 C230, 06 SLK55
Magna Race Wires for $130
Originally Posted by SteveL
Sorry, don't know why the url didn't up. Trying again...
http://alamomotorsports.com/products..._mercedes.html
I ordered from this site and they arrived in less then a week!! $130 paid!! Place those orders boys! Better hurry before they figure this out and change the price. Don't call, just order!
Old May 23, 2006 | 08:38 PM
  #71
C32AMG_FL.'s Avatar
2005 E55
got mine about two weeks ago, same service. fast and cheap!
Old Jun 4, 2006 | 11:49 AM
  #72
Zeppelin's Avatar
C32
After doing a bunch of research on these plugs I kept coming across articles on the IK-22 is the best plug for a slightly modified engine. So I bought a set and have been driving on them for a week now.They do seem to have more power in the upper RPM's which is more than likely due too reduced detonation resistance which allows the ECU to keep more timing in the motor.
One thing I do notice is that the coolant temperature is 5-7 degrees C cooler with the IK-22's. Even in 95 degree heat with the A/C on full throttle blasts and stop and go I have never seen a coolant temp above 97C. Usually it is at 90C.
I am also glad I removed the stock plugs now because they were nearly seized in the heads. I may not have gotten them out if I waited much longer.
So if you live in a hot climate these plugs may be for you.
Old Jun 4, 2006 | 12:49 PM
  #73
SPONSOR
thanks for the feedback...after doing some more research myself, i think i am going to switch.
how are they for daily driving? any difference there?
Old Jun 4, 2006 | 01:40 PM
  #74
Zeppelin's Avatar
C32
Daily driving they have been fine. I doubt there is going to be any down-side to these, they are only one heat range colder than stock.
You want to go through the frustration of changing these plugs again I think it took me like 3 hours because I was re-using the stock plug wires and did not want to damage them.
Old Jun 4, 2006 | 03:43 PM
  #75
SPONSOR
changing them is not that big of a deal, i just hope you used some anti-seize this time on the plugs and some diode grease on the wire ends...makes them much easier to get off and on...
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
