Quote:
yeap, go with Kleemann. It will cost you around $12k installed 420wheel HPOriginally Posted by MBfan89
is it possible for to put a supercharger in the c 55 like they have it on the e 55
Quote:
I thought you can bolt on the E55's blower to the C55 motor since they all have the same 5.4L motor?Originally Posted by E55Cent
You'll need to shove in intercoolers and whatnot too.
Quote:
While the block is the same, the E55 motor configured with a lower compression ratio 9.0:1 thus the AMG blower can run at max boost of 11.6psi per the AMG product manual. The C55 CR is 11.0:1, you'll probably blow something in the engine if you run 11.6psi of boost. As mentioned, Kleeman offers a supercharger kit which runs around 7psi I think. A few people have already done this.
Quote:
some one told me if u supercharge a c55 you would be quicker then the SLR is that a fact or false
Falsesome one told me if u supercharge a c55 you would be quicker then the SLR is that a fact or false
If you go with HPS gen II, it will cost you around $9K installed 380wheel HP
[QUOTE][If you go with HPS gen II, it will cost you around $9K installed 380wheel HP/QUOTE]
With it you also get a number of potential headaches and problems. If your going to spend that much money, I would spend the extra 2-3K on the Kleemann. Just do your dilligence and you'll understand what I'm talkin about. The search function is your door to a plethora of information...
ExploreCurrently Active Users (1)
