70 C / 160 F thermostat
I've been working on a 70c / 160 f replacement thermostat . So far it will fit a C-55 with a M-113 engine , The factory piece is 87 c / 189 f
Opinions , is it needed? Thanks ___PTE___
https://mbworld.org/forums/members/25327-rflow306.html
Take Care Patrick T. Eves
Originally Posted by GTA23109a
Sounds great, but there are a couple pitfalls to watch out for.
First, it's going to suck in winter time as the car will have a hard time maintaining temperature. Been-there, done-that with other low-temp thermostat applications.
Second, the ECU calibration needs to be adjusted so the car doesn't get stuck in "cold-start" mode (for lack of a better description) and run rich as heck thinking it still needs to warm up.
If you can overcome these obstacles (mainly the second one) it could prove a very worthwhile, and cost-effective mod.
Quote from rfow 306 Below
PTE made one for me so I have been able to data log and get some feed back. The car idles at about 167-173 with the ac on and 188 to 192 ac off.
When cruising ac on or off, the temp drops to 165. According to my data logger cold start mode turns off at about 130-140 degrees. The o2 sensor voltage and fuel trim changes around there and looks identical to factory thermostat. Big thumbs up from me so far.
No big hp claims
Part Number for a Clk -C 5.5 N/A
thermostat assy 112-203-02-75 $25.00
The only difference I can measure is the addition. bend & lenght in the neck to clear the compressor belt and $54.00?? . For the compressor one. left in the picture
No big hp claims
going to bring this back from the grave...PTE, did you ever figure out what it will take to get it to work on the C32? i want one, need one, just let me know what needs to happen to get this on my car...thanks
Would you be able to use a thermostat from a C320 and modify that one for my C32 motor? I have my old C320 motor sitting in the shop, and the thermostat housing looks the same. It rarely gets very cold in California...
