installing springs...question
Old Jun 4, 2006 | 07:13 PM
MercedeSC32's Avatar
'07 SLK55, '04 C32, '04 Escalade
hey guys, i'm gettin my set of H&R springs installed this week...my question is i'm gettin the springs installed without any spring pads, will the rear be uneven still? how does the car look like? does anyone have pics of their car with springs + stock suspension installed with or without any spring pads, thanx...
Old Jun 4, 2006 | 07:24 PM
JP@CarLAB's Avatar
No no, you'll want to install with a spring pad even if it's a #1 (lowest?). Please don't do that :\.
Reference:
https://mbworld.org/forums/showthrea...ght=spring+pad
flip
Old Jun 4, 2006 | 08:17 PM
Blake P's Avatar
'09 A4 S Line
In case you're not aware, your car already has spring pads (most likely #2) on the rear, so just have the shop install the springs and re-use the original pads. With the #2 pads and H&R springs, your car will likely sit a bit lower in the rear. People usually use the #4 (thickest) pads in the rear to make the drop perfectly even all around. My advice?...get coilovers and dial in your drop just perfect.
Old Jun 5, 2006 | 08:52 AM
Fifth Ring's Avatar
C32 AMG
Reference:
flip
This reminds me of a question I was unable to answer a couple of months ago.
Do the front springs on the C32 sit on "pads" and if so, is there a chance to lower it by using a thinner pad?
Old Jun 5, 2006 | 08:56 AM
ToboC32's Avatar
The ones that move me
No spring pads on front, just on the rear
Old Jun 5, 2006 | 09:39 AM
so then, i should go pick up some #1 pads for front and rear, for the lowest drop then rite?!
Old Jun 5, 2006 | 11:18 AM
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
no spring pad on the front just the rear..... if you go with a #1 or stock #2 your car might rub. buy #3 #4
Old Jun 9, 2006 | 02:32 AM
nanrye's Avatar
'04 Black C32; '00 Black ML320
Unhappy really really newbie question (might be dumb for some)
Hi, just got my c32 last month and had just found out about mbworld. You guys are great and I already got some great ideas. Just lowered my car this week with h and r springs, used my stock suspensions and spring pads...and yeah, my rear sits a lot lower than the front. I wish I've read about this thread before I did it. Where can I get the #3 or #4 spring pads that you said? (That's my really really newbie or maybe dumb question, by the way...sorry). Thanks.
Old Jun 9, 2006 | 02:59 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
spring pads should be available from the shop if they work on a lot of MB all the time. If not they are available from the dealership.
Old Jun 9, 2006 | 10:23 AM
jtc55's Avatar
08 E63
i have #4 spring pads brand new, still in plastic wrap, if u want to buy them. pm me if interested.
Old Jun 11, 2006 | 06:09 PM
nanrye's Avatar
Thanks for the info.
