Suspension mod questions
) - I still would like to get this car to not push so much through corners and long sweeping turns (yes I'm trying to get off the gas a little too). In any case, I would like to get a MUCH firmer ride and maybe reduce some of that understeer (and drop at LEAST 1" but 1.5 seems to be a sweet spot). Currently I'm looking at either some H&R sport springs (lower the car 1" ) or a used Cup Kit. The price is cheap enough on either of these that I'm not that concerned about making a mistake BUT the Cup Kit I'm looking at is from a C240 - are all w203 cup kits the same or do I need something specific to the C32? In the end I suspect I'll end up with the Bilstein PSS9 coil-overs as that's what seems to be the shizz, but I'm trying to experiment for less than $1000 before I go nuts on something like that. I would like the ride and handling to be much firmer.Also if anyone has anything, or a vendor reads this, speak up, I'm ready to do this now so I can get them in before my next autox event in 2 weeks.
Thanks!
If you are gonna autoX, go with RENNtech springs. It doesn't throw off the ride quality much and improves the handling greatly. H&R springs will do as well, but doesn't work as well with the stock shock.
ALSO - what size front sway bar should I be looking at if I want something more hard-core than stock - also it seems like there are two connections offered by someone like Tire-rack - there is a 26mm with 10mm end link holes and a 26mm with 12mm end link holes.
Thanks!
Weight transfer is a big part AutoX'ing... stiff+stiff+stiff might equal TOO stiff ... consider making changes to your car one at a time.
If the Coil-Over kits for the C-Class allow for ride height, spring rate and independent rebound & compression adjustments (does anyone know the answer to this question?), you'll probably get better "bang for the buck" than from springs & sway bars alone.
Unfortunately I'm new to the Benz family, so I can only make a few general statements like that... Feel free to ignore me all together
Thanks for the feedback in any case!
Might consider an AutoX-friendly alignment for the front (camber &/or toe)... Consider camber only first... but you might wear your tires quicker.
Hey you're Autox'ing ... tires be damned!
ok I'll shut-up & let you get back to after-market parts ...
Thanks!
http://www.evosport.com/product/prod...RS.SUS.M03.W01
Thanks!
