One way to best clean your K&N or Green Filters
this method is THE BEST BY FAR!!!!! it is EASY & FAST!!! & relatively CHEEP too!!!!
OK... i just figgered this out last weekend...arguably the BEST method i have EVER used to clean Cotton gauze air filter media....i have been cleaning these types of filtersd for about 20 years :o now & nothing REALLY seemed to CLEAN the stuff thoroughly......
This started because i have an SRT intake w/a AFE filter, & i was cleaning it the usual way: spray on the cleaner let it sit.. .rinse it out... blah blah... it seemed to work OK... but i could ALWAYS still see dirt & crap stuck into the filter media down deep in the grooves/pleats... this was pissing me off... so i cleaned it three times the last time ...
soak with filter cleaner..let sit, .rinse...
soak again w simple green, let sit in the HOT sun...& rinse...
then AGAIN, soak with with orange glow cleaner & simple green then let sit & rinse....
STILL there was dirt & bug parts & oil grime down in the pleats & even at the ends of the outside pleats..... WTF!! & you DO NOT want to blast it from the inside with a water or air hose.. .you will damage the cotton that needs to stay in good shape to filter properly....
Then..I had an idea......
I got a small bucket... dumped two scoops of that Oxy clean crap /powder in it & then placed the filter in there.....next i poured 1 1/2 $1.39 2 liter bottles of generic CLUB SODA in the bucket.....(about 3 litres total...dep on the bucket you use...use a smaller one to use less Club Soda etc...)
WELL!!! that **** bubbled & foamed up almost Instantly & this greasy dirty film & TONS of dirt & crap just freaking JUMPED out of the filter gauze!!!!! the foam was all topped with this yellow filter oil & dirt & grime & bug detritus .. .it was amazing that all this crap was STILL in there after cleaning it traditionally 3 times..... the Club Soda was the trick for SURE the carbonation in that just 'boiled' the crap out of the cotton gauze fibers instantly...!!
SOO much crap came out i ended up using a piece of paper to scoop the nasty oily grime & dirt & such that was riding on top of the foam in the bucket out & dumped it so i would not have to lift the filter up & out thru that ****.... i swirled the filter around in the solution for about 3- 4 minutes & then let it sit for a minute or three.....finally I just shook it in the solution for a few seconds & pulled it out... OMG.. .it was CLEANER than NEW!!! I mean it was SPARLKING clean!!!! elapsed time: 10 minutes MAX!!
ALSO....this is VERY gentle on your filter media.. .(cotton gauze) & is MUCH better than blasting it with water & or air trying to rinse out the crap or blow it out all of which are highly discouraged by the filter makers....
let it dry properly, (Note without all that residual grease & grime still clogging the filter.. .it WILL DRY MUCH FASTER
!) then oil it up & reinstall.... i actually have two filters so i do not have to wait on drying & oiling the filter to drive my car when cleaning filters i just keep one all oiled & clean & ready then i can take my time cleaning drying & oiling up the other one.... you can use ANY cleaning degreasing solution I would imagine...it was the Club soda not the 'Oxy clean' that made the HUGE difference.. but feel free to copy this method to a 'T' if you want to....
this should be a sticky!!!
you are all welcome....!!
Ed G.
Sounds like a great thing to do - oxyclean is only sodium percarbonate and the pH is < 10.5 so it would probably be just fine on a cotton filter.
A question for you - have you looked at the filter since doing this cleaning method? i.e. how clean are the walls of the airboxes on the clean side of the filter?
I still have stock filters on my C55 and probably be replacing with Frams, paper is paper to me.
Now I need to recharge/re-oil these...
I have yet to try this method.
Do I need to oil the filters? Is cleaning with water going to be satisfactory?
Also, cotton gauze filter recharge kits sold by K&N and Green all have 2 bottles, a bottle with cleaning agent, and a bottle to re-oil the filters. The sticky oil is what traps the dirt.
