Going to fab up my own intercooler reservoir...
if you do the heat exchanger without the seperate reservoir, i don't think it will be worth it, honestly...just don't think it would make that much of a difference because you still have the intercooler fluid mixing with the hot engine coolant...just my .02
I may be interested in doing the heat exchanger, but I don't want to move the battery.
I still need to get my ScangaugeII to work, to measure the IAT baseline, it does not seem to want to communicate, with the OBD2 port on my C32.
BTW, Evo's cooling upgrade does not nullify the use of winshield washer fluid. I believe most of us who have this upgrade (including myself) runs the winshield washer fluid through the intercooler, since the system is separated from engine coolant circuit. I wonder why Vadim did not mention this. I believe there was a whole discussion about the use of window washer fluid as a cooling media for the intercooler system besides coolant.
I like the way it is for me now, since my window washer fluid is truly "heated" and boy does it wash well
. In case you were wondering, I have been running EVO Stage II for 3 years now (30K miles) without ill effects of using window washer fluid for my intercooler. Just have to make sure I top the tank off every so often, since the more you use your washer, you are depleting your cooling medium!
. In case you were wondering, I have been running EVO Stage II for 3 years now (30K miles) without ill effects of using window washer fluid for my intercooler. Just have to make sure I top the tank off every so often, since the more you use your washer, you are depleting your cooling medium!i understood that this was the case with the evo washer mod to begin with...
there were two things that i did not like about this option, not saying it doesn't work, i just wanted to have washer specific fluid in the washer tank...
1. i run a specific type of intercooler fluid that could is not a great idea to allow contact with your paint on a regular basis...it helps with cooling better, that is the only reason i would rather run this fluid than the washer fluid with some kind of methanol mix...
2. i wanted a seperate reservoir that i can fill with ice at the track that won't let the ice circulate through the system and trash your intercooler pump...
If I go the windshield washer fluid route, I'm going to buy a new tank, fittings, hoses, and clamps to add it to the coolant system. I like Vadim's idea about hooking up a Johnson pump to a relay switch during rapid cool down phases at the track.
what i did is very complex and not for the faint of heart, even with instructions, it will take quite a bit of mechanical skill in order for the upgrade to go smoothly...but i believe the benefits are worth it
on another note: has anyone picked up the latest copy of Modified's Luxury & Exotics? i picked it up friday at barnes and noble and they had a great article in there about a Renntech SL55 with custom twin intercoolers!!!!
Dynocomp in Arizona did the work...guess who i am calling next?
i don't have a scanner, but if someone that does have one can pick up the magazine and post it up here, it would definitely be relevant to the current discussion...
http://www.designengineering.com/pro...p&pid=62&tid=1
It seems one should only need to add deionized water to mixture.
this will allow you to keep your winsheild washer tank intact and have your intercooler fluid seperated out...
