Plug in glovebox?
C32 AMG
Plug in glovebox?
So I noticed the aux plug for what looks like a headphone jack inside of the glove box. I picked up a male/male cable and thought that I would be able to run my iPod through there...wrong. It doesnt do anything and I can't figure out what the heck it's even for. I have the 6 disk changer and Nav. setup. There is a blank button on my head unit on the far lower left that looks like it should be for "Aux" or something but it doesn't seem to do anything. What am I missing here?
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
Black 2002 C32 AMG
headphone jack inside of the glove box???? I need to go see this
I would love to have an AUX into the stock audio system for my 02. Thanks for the heads up!
2004 SL55, 2015 A250d, 2016 GLC250d
On newer COMAND-APS and Audio-20 systems, it often can be added - but for some while it hasn't been installed as standard. Can't remember how you select it on COMAND-APS or Audio-20 ..
R
It is there on cars with COMAND - and you have to select AUX input via the SYS button to listen to it
R
R
R
C32 AMG Maserati Coupe GT
I have one too. It's the AUX input, you need to go into SYS mode to enable it. On later models, the wire to the door frame is there, but they never put in the socket.
It's one of the C-class DIY projects if you don't have one and wish to install it yourself.
This thread has all the info you need: https://mbworld.org/forums/showthrea...od+integration
C32 AMG
Thanks for the info guys. I figured there had to be a way to get it into Aux mode. I'll play with the SYS or CDC crap next time I'm in the car. I'm glad it's already installed though so I don't have to to the DIY project that dchoa did. BTW great pics and install dchoa. That is exactly what I was talking about. I have that already, just need to make it work.
C32 AMG
Well, curiousity got the best of me and I had to run outside and check. Sure enough it was a very simple process to get it to work. All you do is plug it in, hit SVC, go to Settings, and select Aux. Thats it.
Works great and not only works for the iPod, but Serious/XM recievers as well so you can get better sound and not have to run it through the FM transmitter. I'm pumped! ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Nobody should waste the money on the iPod setup from Mercedes if you ask me. If you don't already have this jack, you're much better off just following dchoa's install and going that route. Put the money you save into something under the hood.
Thanks again for the info guys!
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Thanks again for the info guys!![drive](https://mbworld.org/forums/images/smilies/driving.gif)
C32 AMG
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Glad others can get good use of this. This is a great stock feature that I'm suprised more people don't know about. Seems silly to bother with the expensive aftermarket setups.
