C32 Transmission
I am a newbie to this forum and I need you help! Here is my situation: I own a 2002 C 320, and decided to replace the engine/transmissio/differential with with those with a C32. I got a very good deal for them in a local salvage yard. All is good and the car started after we reflashed the ECU. However the transmission I bought did not come with it's TCU. It's sticking in one gear. It will shift normally until it gets stuck in one gear, and sticks there. My mechanic says that i need the AMG "code" for the tranmission control unit so that he can enter it the TCU, and it will work fine. I am not able to find such a code. He told me (and several other experts) that a code from any AMG car will do. I need that code. Can you help me out you guys?
My mechanic has access to the factory scanner he said what we need is the EGS code (4 digit ex: ef0g) for any AMG transmission. Can any one retreive that for me from there TCU?
. In German its called (EGS-Codierung).
https://mbworld.org/forums/showthread.php?p=1861566
The one I saw was for a C32, as I was thinking about picking it up because I have the tranny jerk and this one was for an 03, which might fix it.
At any rate, this was a few days ago and I don't see it anymore.
