heated seat
Old Dec 27, 2006 | 08:11 AM
john89011's Avatar
MB C32 AMG
heated seat
My driver's side heated seats don't work. When I push the button, no response and the red light does not come on. The passenger one works fine.
Any ideas other then checking fuses because I checked those. Bad relay?
Thanks guys!
Old Dec 27, 2006 | 09:29 AM
sales@eurocharged.com's Avatar
SPONSOR
C63S
Thanks guys!
I believe it's a known issue. Try searching because I have read about this a few times.
Old Dec 27, 2006 | 09:38 AM
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
no light? fuse?
Old Dec 27, 2006 | 09:47 AM
john89011's Avatar
MB C32 AMG
Yea the light on the heated seat button does not come on like it suppose to. Checked the fueses and they are fine, I even replaced the fuses just to make sure and still nothing. When I first noticed it the light did come on but the seat would not get warm
Old Dec 27, 2006 | 10:08 AM
SUNILP's Avatar
2015 E250D
If the light does not come on then you have an open circuit. The connector under the seat (4 position connector) may be disconnected or the element inside the seat is bad.
Old Dec 27, 2006 | 11:26 AM
SilverBulletAMG's Avatar
C32 AMG
Mine lights up but the seat won't heat. This is a known issue. I heard someone on here received a whole new drivers seat out of the deal. I have a laundry list of issues I'm taking with me to the dealer after the holidays. Thank god for extended warranty!
Old Dec 27, 2006 | 06:56 PM
Glasgow Gold's Avatar
'03 C32
I also had this problem (switch lit up, but bottom part of seat didn't warm) and dealer replaced entire bottom seat under CPO warranty.
Was concerned that color of leather wouldn't exactly match up with seat back (which wasn't replaced) but it looks fine.
This was really the only problem with the car in my 18 months of ownership!
Old Dec 27, 2006 | 08:21 PM
360_iti's Avatar
W203, W211, W219, W212
It is a common problem. It happened to me twice within a year.
Old Dec 27, 2006 | 08:30 PM
SUNILP's Avatar
2015 E250D
sounds like a broken element on the bottom seat cushion. They will replace the leather but not the entire seat bottom. Foam and frame will remain the same. The leather has to be replaced since the element is integrated with the leather. However, since your seat buttons do not light up at all, then it sounds like a bad connection under the seat or behind the switch row.
Old Dec 28, 2006 | 12:49 AM
john89011's Avatar
MB C32 AMG
Ya it's just a pain in the a** cuz everything seems to go like right after the factory warranty: my SC, IC pump, heated seat, steering wheel motor, connection to fuel pump all went. Although once I floor it I forget about all these problems
Old Dec 29, 2006 | 08:01 AM
Bobby Dazzler's Avatar
2003 C32 AMG, 2003 ML270 CDi
Spot on.
If out of warranty it's possible to use the separate element from a different model, which has the same connectors. Works out cheaper than buying the whole cover. I'll try to dig something out for you.
Old Dec 29, 2006 | 08:17 AM
jwanee84's Avatar
2002 C32 AMG
yup, ive got this problem too. I have yet to fix it and its getting cold out.
Old Dec 29, 2006 | 08:20 PM
iceking69's Avatar
2002 C32 AMG, 1991 SL500 AMG sport
I have same problem with my driver side bottom seat. Hey Sunman, Can you take the heat element off the seat cover and then put it back or is it stitched to
the underneath side of the leather. Sounds like youve done a lot of work especially on the C class.Thanks
Also what does it cost in parts to do the Parktronic front and rear on 02 C32
Old Dec 31, 2006 | 11:33 AM
SUNILP's Avatar
2015 E250D
the heat element is stitched into the cover so you can't just remove it.
Old Jan 2, 2007 | 01:29 PM
john89011's Avatar
MB C32 AMG
Could it be that it's just the heated seat button that's bad? I'll try to unplug the heated seat botton and then test it for juice to see if anything is going through or just plug it into the passenger's one and see if it lights up. I still have extended warranty but it's a b**** with these warranty companies I just don't feel like going through the process. If it's a bad relay i'll just replace that but if it's the element I guess i'll go to the dealer. Also if they replace the bottom since I have two tone leather black/ blue will that be the same or will they just give me a black bottom seat? Or I might try to unstitch the element and stitch it back on if the dealer sells the elements indevidually.
Old Jan 2, 2007 | 03:59 PM
Apparently they are completely integrated, and so can't really be unstitched. Better to leave them there and simply add heated pads if you want to keep the same cover.
Shouldn't be a problem getting the black/blue seat cover if you decide to get it done through your warranty.
Old Jan 2, 2007 | 04:30 PM
Take a look here for some information on adding separate pads.
Hope this helps...
Old Jan 2, 2007 | 07:28 PM
boohooramblers's Avatar
Not an AMG :(
Hope this helps...
Same happened me - the bottom pads don't heat up on the driver or passenger sides. I'm getting mine done under warranty next week (thankyou starmark!). The SA said they were $850 each! Phew!
There has been some dude trying to sell C32 seats on e-bay for the last couple of months - I believe the price has been dropped significantly now (certainly less than the price of one heating pad!).
Old Jan 4, 2007 | 12:48 AM
john89011's Avatar
MB C32 AMG
Thanks for the input Bobby Dazzler, I also came across this site
http://www.heatedseatkits.com/heatedseatkits/index.html
A buddy of mine had these installed and he said they work great, not on a Benz though. I'll see if I decide to do this on my own, I'll def. document and put pix on the forum for future references.
Old Jan 4, 2007 | 04:45 PM
You're very welcome!!
Old Jan 19, 2007 | 01:17 AM
Not an AMG :(
After having my car at the dealership for 2 weeks now, I finally get a call from my SA who tells me that they don't want to replace my heated pads because they are saying that my VIN doesn't match with the parts and he is trying to tell me that my C32 didn't have heated seats!! On top of that, I am now being accused of adding aftermarket seats to my car!!
This sounds like BS to me. I've tried to research what was standard on the '02 C32, but can't reach a consensus on the heated seats. Am I right in saying that it was pretty much standard on the '02? (a question to anyone out there who bought their C32 new).
Meanwhile, I'm driving a C230 loaner around that doesn't have enough power to drive out of a wet paper bag..........
Old Jan 19, 2007 | 01:33 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
I read before that heated seats were OPTIONAL on 2002 and 2003 C32
Not sure about 2004...
Old Jan 19, 2007 | 03:03 AM
Eurocharged Rick's Avatar
SPONSOR
my driver seat just quite working today...going to have to check it out, lights on the switch will not light up.
Old Jan 19, 2007 | 03:44 PM
lap's Avatar
lap
From: Great White North (the one with the crappy dollar)
2002 c32
in Ontario
bought my c32 new in 2002 in ON Canada, Heated Seats were OPTIONAL ...so was Sunroof!
Old Jan 19, 2007 | 10:12 PM
SPONSOR
so have you come to a conclusion john, mine is doing the same thing that yours is...fuses are fine
