Intercooler Pump
'03 S55 AMG, '01 CLK55 AMG
Intercooler Pump
Does anyone know if the Intercooler Pump on the S55 is the same as the one on the C32/E55? Are they interchangeable?
I read that you can replace it with the pump off a Ford Lightning which can be found on Ebay for less than $100.
s55 i/c pump
Here is the link to a picture of Lightnings i/c pump (the biger one)
Hope it will help
http://www.key-ideas.com/DG_AirtoWaterICPump.htm
Hope it will help
2002 C32 AMG, 1991 SL500 AMG sport
Actually the Lightning pump needs a few minor tweaks to use on a C32. The new
Cobra though is suppose to be an exact fit. I hear you can pick it up at any dealer for about 60.00 retail.
quick correction i/c pump at Ford dealer exactly $394.99 in chicago i called them on 12/27/06 myself at www.buyfordracing.com only $95.00 with shipping
S600TT, R350
The Bosch pump used on C32 is the same externally as all 55 Kompressors, all Ford SC cars, including Range Rover and new Shelby.
55s use slightly higher rated pump, about 10% more flow, but it has the same dimensions.
There is a connector difference between the makes, but it can be easily fixed by cutting and splicing.
Intercoler pump revisited
There was once post with exact explanation how to replace this damn pump.
I can't find it anywhere.
Does anybody have it saved. Please PM.
Thanx in advance.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Thanx in advance.
