Pesky ESP
Old Sep 17, 2002 | 06:11 PM
jeffclevenger's Avatar
2003 C32 AMG
Pesky ESP
I now have had my C32 for 3 weeks & I am starting to learn how to drive it right. Seems my ESP OFF button does not really turn it off though. Any hint of tire spin & the "!" triangle flashes & the throttle is eased off - makes it hard to charge out of corners. Anyone have this figured out?
Old Sep 17, 2002 | 07:54 PM
JustinTRW's Avatar
C32 AMG
Yes, it's called feathering the throttle. That yields the quickest launches out of the turns.
Old Sep 17, 2002 | 08:06 PM
Bux's Avatar
Bux
G
damn your esp is sensitive...
can you do burnouts with esp off?
Old Sep 18, 2002 | 12:38 AM
2003 C32 AMG
I have not really tried to do a burn out. It will spin tired slightly for sure. I did a 0-60 with my G-tech & hazed the tires just a but from an idle launch (time was 5.4). When I power out of a corner, it seem to want to rocket & then the "!" flashes & the momentum is lost. I think this might even be dangerous on a race track if someone is following closely . . .
Old Sep 18, 2002 | 12:42 AM
AMGDood's Avatar
C32 AMG
Does anybody know how to post a video? If so i can post one of me doing probably the biggest burnout possible for our cars.. I destroyed my tires.
Old Sep 18, 2002 | 12:43 AM
JustinTRW's Avatar
C32 AMG
Potential slipage to the point when ESP cuts off everything is a non-issue at the track because speeds are too high. The car is simply not powerful enough to case this phenomenon. I have experienced what you are talking about, but only at low speed.
This is not to say that ESP will not engage on the track, but your goal is always to drive smoothly enough as to where it will not want to. Yes, it would be nice if ESP would shut off in full.
Old Sep 18, 2002 | 12:52 AM
JustinTRW's Avatar
C32 AMG
Send me an e-mail at singh.justin@***.net.
I'll see what I can do.
Old Sep 19, 2002 | 01:46 AM
JustinTRW's Avatar
C32 AMG
Video
Ok, I have temporarily posted AMGdood's video on my personal webspace until I can find a better place. The link may not work if the traffic bandwidth has been exceeded. I'm trying to find a more stable place as I write this...
Check it out:
http://members.***.net/singh.justin/C32%20Burnout.mpg
Old Sep 19, 2002 | 03:55 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
nice burnout video AMGDood.
btw What high school do you attend to ? seems like something not an average kid would do when their parents pay for the car.
Old Sep 19, 2002 | 07:15 AM
2003 C32 AMG
I did a quick check on the burn out - definitely will smoke the tires from a stand still (not nearly to the extent that Justin's training video show, though :-). My problem seems to be only in corners. I do understand the concept of smooth driving for fast lap times. I have lapped with NSXs, Vipers & Ferraris in my mostly stock Dodge Neon. If the tires are not squeeling, though, you are not going as fast as you otherwise could. Can get the tires to squeel on the C32 without the fun cops (ESP) busting up the joint. Has anyone tried removing an ABS sensor cable to see if that would shutdown ESP? Kind of extreme, but with std ABS, that usually works on other cars. Thanks -
Old Sep 19, 2002 | 12:46 PM
JustinTRW's Avatar
C32 AMG
There seems to be a way to completely shut off ESP from the steering wheel controls, but it takes ABS with it. The shutoff lasts until you turn off the car...I think maybe one of the Evosport guys knows how to do this. It was mentioned at c32life.com once. You can't get the tires to squeel without ESP coming on? Intresting. This is at what speed? Oh btw, the video is not mine, I just posted it for the owner.
Amarveet (AMGdood): Don't you think that is just slightly abusive? Very impressive I must admit, but I'd never do it. Your friends in the backround seemed to have gotten a kick out of it.
Old Sep 19, 2002 | 01:49 PM
JustinTRW's Avatar
C32 AMG
Jeff, try this:
Originally posted by Lynn
How do I disable Traction Control completely?
To start, the key must be removed from the ignition.
Insert the key and turn to position 1.
Immediately press and hold the trip odometer reset button until the instrument cluster beeps. There is no visual message, only an audio beep. Be patient, this takes around 40 seconds.
Press the lower menu button (it looks like two sheets of paper, the one with the writing in the background behind the blank one)
Press the up arrow button.
Press the "+" sign to disable the Traction System (turn "ON" test mode)
Start the engine, the traction system is now disabled.
To return to normal, remove the key and restart the engine. The traction control warning should no longer be in the cluster. If it is, shut the engine off and remove the key again. Then insert the key and turn to position 1. Note that the DYNO test screen is displayed immediately. Push the "-" button to enable the traction system (turn "OFF" test mode)
Note : When you first turn the key to position 1, ESP DYNO Test screen pops up, then after 1-2 seconds it may disappear while faults are displayed. If you weren't fast enough in pressing the "-" button before codes were displayed, just wait until all codes cycle by, then the ESP DYNO Test screen will reappear.
It should work.
Old Sep 19, 2002 | 01:56 PM
Mach430's Avatar
That brings back memories...
Old Sep 19, 2002 | 02:05 PM
JamE55's Avatar
Out Of Control!
Originally posted by JustinTRW
Jeff, try this:
It should work.
Just curious does this method work for the W210 chassis too?? Anybody?
Old Sep 19, 2002 | 03:11 PM
EBMCS03's Avatar
Re: Video
Ok, I have temporarily posted the video on my personal webspace until I can find a better place. ... I'm trying to find a more stable place as I write this...
Ok here's a more stable palce... it should work
Right Click and save target as (~1.2MB)
Old Sep 19, 2002 | 04:19 PM
vraa's Avatar
dling the vid right now..
Old Sep 19, 2002 | 07:49 PM
AMGDood's Avatar
C32 AMG
thanks for posting the video Justin. Sorry its soo blurry and sorry my friend is laughing so hard. He has a C240 so he wasnt use to seeing burnouts like that. jk I hope all you guys like it.
Old Sep 20, 2002 | 01:44 AM
JustinTRW's Avatar
C32 AMG
It's clear enough, the amount of smoke is clear! At what RPM did you let go of the brake pedal?
Old Sep 20, 2002 | 01:56 AM
Mach430's Avatar
AMGDOOD:
This pictures is for you CLK430 stock at about 5000 rpms in 4th or 5th gear. Standing still!
Old Sep 20, 2002 | 01:59 AM
JustinTRW's Avatar
C32 AMG
I've gotten a few e-mails from people wanting to know how to do a burnout. Do I dare tell them? Opinions on this matter? If you can't figure it out on your own, maybe you can't handle it? I'm babbling.
Old Sep 20, 2002 | 02:45 AM
EBMCS03's Avatar
Hahahaha i dont know what to say... why dont u want to tell them how to do a burnout? tell them and say its the best when u have a new set of tires. LOL
Old Jun 19, 2003 | 09:43 PM
Marc's Avatar
Jeff, try this:
It should work.
Justin -
Do you happen to know how to disable ESP completely on a 2003 SLK32 AMG? I tried following the instructions, but the SLK32 has no controls on the steering wheel.
Thanks,
Marc
