2002 to 2003 differances...
Old Jan 17, 2007 | 09:42 PM
RacerX0911's Avatar
guys i already searched and i came up dry...
what where the differances between the C32's from 2002 to 2003...is it worth paying the extra for a 2003 if i find a 02 with just as many miles...only thing pushing me towards the 03 is that warranty is still good. unless i can find a 02 that is certified to 100K
last question is...i know that the warranty is a big thing for these cars...so if i get a used 03 under the warranty and i want to extend it to 100K. can i? and say if the warranty is already expired can i get it certified for a resonable amount...?
thanks in advance guys...
Old Jan 17, 2007 | 09:53 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
One noticeable difference is that the 2003 has clear head lights while 2002 is a little foggy.
I don't think Navigation was available on 2002 models.
If the original manufacturer warranty expired, then you will NOT be able to extend it through Mercedes, for example, STARMARK warranty. But you may be able to get an after market third-party warranty.
If the car still had the manufacturer warranty, then you can purchase extended waranty through your local Mercedes dealership.
The two cars are very close, and even though there might be minor differences, I think you should ultimately decide by how good of a deal you're getting. If you find a "good" deal, you should take it on either model.
Good luck...
Old Jan 17, 2007 | 10:09 PM
jgsx's Avatar
04 C32
2003-2004 only had clear BIXENONS! The Halogens were still frosted
Old Jan 17, 2007 | 10:10 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Navigation was available on the 02. Mine has it.
A few drivability issues are at stake betweent the two years. The Transmission TCU was re-programmed in 03 to help eliminate the "jerk" between 2nd and 3rd. Upgrading the 02's TCU should correct the problem. Also, Vadim @ MBLN pointed out that the 02's intercooler pump is always running as the 03's runs only when the S/C is running. This can mean a difference of 20 degrees air temps in the S/C, meaning better performance.
I'm no expert so don't take my advise as the gospel truth. I'm just doing my best.
Old Jan 17, 2007 | 10:31 PM
Kar don's Avatar
Mercedes-Benz
03 warranty cannot be extended by MBUSA, only 05 and up can be extended. I'd get whichever one is in better condition.
Old Jan 18, 2007 | 01:26 AM
Stomlo's Avatar
'03 C32
When did Merc change the controls for the steering wheel adjustment from the door (by the seat controls) to under the steering column?
Old Jan 18, 2007 | 03:59 PM
RacerX0911's Avatar
guys w/o a warranty on this car im pretty much screwed repairs wize...right?
Old Jan 18, 2007 | 04:26 PM
360_iti's Avatar
W203, W211, W219, W212
Yes. Pretty much. The parts aren't cheap, and labor is expensive too. You can buy an extended warranty if the car has less than 45K miles, even if your factory warranty has already expired.
Old Jan 18, 2007 | 04:57 PM
amgmark's Avatar
ML63
Another small difference.. The door pillars on the 02 have a CF look, little squares.. and the 03+ just has a plain black pillar.. just thought I would mention..
Old Jan 18, 2007 | 05:11 PM
Vomit's Avatar
2002 C32 Black/Charcoal
02 no spare tire
03 spare tire
Some 02s have no moonroof
All 03s have moonroof (I think?)
Old Jan 18, 2007 | 05:22 PM
moosejaw's Avatar
none
2003and + have a fresher hvac panel interface with arrows on the temperature buttons instead of the colored buttons. Also 2002's did not not an engraved engine plaque on top of the intake manifold
Old Jan 18, 2007 | 05:29 PM
360_iti's Avatar
?? pic ?
Old Jan 18, 2007 | 10:02 PM
m444's Avatar
Audi C7.5 S6
Some early 2003 C32 did not have the signature plate on the supercharger.
Mine does not have it, 2003 model, sold in Aug 2002.
Old Jan 18, 2007 | 10:33 PM
jgsx's Avatar
04 C32
Were you the original owner?
Old Jan 18, 2007 | 10:49 PM
sales@eurocharged.com's Avatar
SPONSOR
C63S
I think only the 02 models have the electronic steering wheel adjustment on the drivers door.
I have a vent on the dash board that I don't think is on later models.
I think a read somewhere that the first aid kit was relocated but I'm not 100% sure.
Old Jan 18, 2007 | 10:58 PM
amgmark's Avatar
ML63
This is the one that bugs me about my 02.. My SC has been replace and there is just a blank space there..
A forum member pm'd me that they had a couple from their shop.. but after initial contact I haven't heard back.. Guess I should try again..
Old Jan 18, 2007 | 11:09 PM
360_iti's Avatar
amgmark, let me know ok. I have a blank space as well since my sc has been replaced.
Old Jan 18, 2007 | 11:37 PM
ralleyone's Avatar
2002 C32 and 2009 Audi S5
I was thinking about adding my own signature there to really drive the value down.
Old Jan 18, 2007 | 11:58 PM
amgmark's Avatar
ML63
If you were trying to be sarcastic regarding my post, they were real AMG plaques not knock offs.. the shop did a couple SC swaps.. I really don't care if its the original builder as long as the ugly *** blank spot is gone.
Old Jan 19, 2007 | 06:27 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Good luck...
clear headlight's only for 2003-2004 cars with bi-xenon option.
2002 has the Navigation option.
other than that there are three differences:
the 2002 has the cf looking exterior b-pillar while the 2003-2004 switched to the cheaper looking shiny plastic.
the digital climate control buttons in the 2003-2004 is less sticky, but does not look as good.
the later 2003-2004 has the engine plaque that says who built ur engine if you can read the tech's signature.
Old Jan 19, 2007 | 06:31 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
what was wrong with you guys's s/cs?
Old Jan 19, 2007 | 08:35 AM
MIDO's Avatar
From: Home is Stockholm, Sweden. But my work takes me around the world, right now I work/live in Laos, South East Asia.
C32 T 2003. Mods? MANY!! :)
Originally Posted by Vomit
02 no spare tire
03 spare tire
I have a 03, NO spare tire....A late 03.
Old Jan 19, 2007 | 11:42 AM
Vomit's Avatar
Cool. I would probably have removed mine if it came with it anyways. I thought all 03s came with a spare, but I could be wrong
Old Jan 19, 2007 | 11:52 AM
m444's Avatar
Audi C7.5 S6
I bought the car from the original owner. We talked about the car and history, before I bought it. He gave me every receipt, paper and dealer work order on the car. He was meticulous about the car and never drove it in the rain or left it out in the rain.
It did not come with a signature plate.
Old Jan 19, 2007 | 03:56 PM
RacerX0911's Avatar
i just talked to our Mercerdes dealer and he told me i would have to get a certified pre owned and then you can buy a additional warranty after your certification is over... the problem is that i want to mod my car...and they want $2100 for one year after the certified and 4K for a 2 year which comes out to 7 years 100K miles...worth it? the one that is 2100 gives me 6 years and 100K miles
- and for free then give me 5 years 100K miles...(all depends on when the car hit the road...)
now my other big question was those of you that are hitting 50K miles and the pumps are going out and s/c failing... where most of the problems in your 50k...so are these warranties absolutly needed?
