seat control module
Old Feb 9, 2007 | 12:00 PM
john89011's Avatar
MB C32 AMG
Exclamation seat control module
Any of you know which plug I have to disconnect under the seat in order to disable the seat control since many of you posted that that's the probable cause of a battery drainage. There are like four different plugs right under the seat and I don't want to pull the wrong one.
Thanks Guys!
Old Feb 10, 2007 | 02:13 PM
Vadim @ FD's Avatar
S600TT, R350
Pull the longest (widest) one. It has power wires in it.
Old Feb 10, 2007 | 02:54 PM
gaz's Avatar
gaz
C
I would recommend you pull the two towards the front of the car to check for battery drain. They are the easiest ones to get to. The ones to the rear of the unit go to the seat motors themselves. You do not need to unplug these to check for drain.
Old Feb 10, 2007 | 04:03 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Or just unplug the fuses that power them..... pretty simple to get to the fuses and what nots Lots of threads in the w203 (non amg section) that can help ya with this...
GL,
-j0hn
Old Feb 12, 2007 | 09:38 AM
john89011's Avatar
MB C32 AMG
Thanks for the input guys. I pulled the one for the power seat control as well as heated seat and it's not draining my battery any more. Short term fix untill I get the seat control module replaced.
Old Feb 12, 2007 | 03:31 PM
SUNILP's Avatar
2015 E250D
glad you got it working. Retails for 145.
Old Feb 12, 2007 | 07:05 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Woah... $145... Where did you find it for 145 sunman?
Thanks,
-j0hn
Old Feb 12, 2007 | 07:07 PM
SUNILP's Avatar
2015 E250D
i just ordered one for a client and if I remember correctly, it's 145 retail.
