Dreaded Valeo radiator confirmed on board my C32...no leaks yet...replace with Behr?
Old Mar 5, 2007 | 09:55 PM
AMGV6K's Avatar
C32 AMG
as the topic says, it's been confirmed that the dreaded valeo on board...although no leaks has been found yet i think it's a ticking time bomb as my car reaching 50k miles on board
should i go ahead and replace it with a Behr radiator? pros/cons? where to find a good condition used Behr? for a peace of mind and avoid costly gearbox disaster
c32 build on september 2002, any chance of it having an updated Valeo?
Old Mar 5, 2007 | 11:58 PM
gkstar's Avatar
C32 AMG - in Pewter
My car's production date is about the same, I have a Valeo and a coolant loss. Car is going to the dealer this Thursday and I will post the result.
I am not sure if the rad leak is as sure thing as the I/C pump failure, but I would wait until I see some coolant loss and then replace rad and transmission fluid. That is if I did not have the extended warranty. I will leave it to the dealer in my case but will also provide all stats that I have gathered on this forum and then pray
Old Mar 6, 2007 | 09:18 AM
Fifth Ring's Avatar
C32 AMG
I have a Valeo and so far, so good. But I intend to change the transmission fluid soon.
Would it be possible to have a dealer run the glycol test on transmission fluid if they do not do the fluid change? (I'm out of warranty.)
PS: I'm told that the radiator swap is not that big a job.
Old Mar 6, 2007 | 09:46 AM
AMGV6K's Avatar
C32 AMG
they need 1 litre of oil to test for glycol (meas in mg/l) so i think yes you do need refill the oil in the tranny
leaking valeos seemed to be a common problems too...so for peace of mind i need to get Behr rads as soon as possible before the tranny disaster
Old Mar 6, 2007 | 10:21 AM
TJ_Andrews's Avatar
2002 C32 ///AMG
I just replaced my Radiator / Coolant / Transmission fluid, I bought this radiator:
http://replacement.autopartswarehous...diator&dp=true
Should be the first one on that page, the Behr, for $221. I shipped it overnight and it was very fast from that website. From all the horror stories, it's best to just get it done with if you have a 2002 C32. I just got mine and couldn't be happier so far :-) Just got my new grill too, but too bad the headlights I orderred were messed up upon arrival.
Old Mar 6, 2007 | 01:52 PM
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
how long did it take u to install the new radiator?
Old Mar 6, 2007 | 02:02 PM
TJ_Andrews's Avatar
2002 C32 ///AMG
I actually got a friend that's an MB Tech do it. Doesn't seem like too hard of a job though, I just didn't want to mess with a tranny flush myself, and figured he would do a better job anyway. Although, if you buy your own radiator, you can't take it to mercedes and have them do it I don't believe, they won't install any aftermarket stuff.
Old Mar 6, 2007 | 03:30 PM
moorfan's Avatar
2002 C32
Don't look for a used Behr. Its like looking for used underwear on Ebay. The new radiator by Behr is in the low to mid $200 range.
I got rid of my dreaded valeo also. My service advisor insisted that if I had coolant contamination that I would see transmission oil in the coolant reservoir, but oh well. I didn't have any evidence of contamination that I could see. If you could see it with the naked eye there wouldn't be a glycol test now would there?
I did the job myself. I would estimate that the job would take between 4-6 hours for the non-MB tech type (me). However, I did many things at once, such as:
cleaning all associated parts (fan, shrouds, etc)
replace intercooler pump
replace thermostat
replace hoses
replace belt
thoroughly flush out old stupid green coolant and replace with M-B original.
All of this took me about 2.5 days. No major snags during the process, other than reaching that damn crankcase coolant drain plug.
regards,
Pete
Old Mar 7, 2007 | 11:17 PM
crystal_ice's Avatar
C32 AMG
May i ask what's the milage on your car right now? I have a 2002 C32 with a production date of Feb 2002. I have no leaks yet but i want to replace the radiator before it leaks
