Should I do it? C32 > C55
Ralf (Temecula, CA)
C55 all the way!
go get a C55, they almost the same car. But C32 is not faster
than the C55. You might want to wait for the C63 for your trade in.
So to answer OP's question, I think it depends on what you want to do w/ the car. If you want to put some mods, C32 would give you much better bang for the bucks. But if you want to keep it stock, C55 is the way to go IMO.
But $10k+ does not seem to make sence to me. From my quick review of auto trader, ebay etc....it seems you will need maybe $15k plus taxes and reg. No way..spend $2500 and get an aftermarket w.... then sleep tight till you have the cash for an E55 or S65
But you already have the C32 . . . if you can get an extended warranty on it, I'd keep it. If you can't, I'd upgrade. I wouldn't want a Benz w/o a warranty, especially an AMG since everything is so expensive.
The one area where the C32 really shines is in modification potential. Throw on an $850 ASP pulley and the car will be significantly quicker than a C55. Add an ECU retune or the full stage 2, and the car will have some *****. The mods are pretty stealthy, so I really doubt you'll have warranty issues with the dealer. I've taken my car to two dealers and neither knew my car was modded. If you throw a supercharger on the C55, I wouldn't be suprised if you had warranty problems.
It is also easy to freshen up the C32. I upgraded my cluster, and I like it much better than the one that the C55 has. I also like my entire interior better than C55, minus the seats.
In my opinion, there are 2 advantages to the C32 over the C55: 1) if you want to modify your car's engine, you can get more HP gain per dollar with the supercharged V6 than the naturally aspirated V8 of the C55, and 2) the C32 has a more comfortable ride because of softer suspension.
Having said all this, I personally wouldn't trade up from a C32 to a C55. Even though the C55 is better in almost everyway, it wouldn't be enough of a change for me. If I were you, I'd rather wait for the next C63 or even the next M3 (which will probably come as a 4 door sedan too).
Here is a pic of the C55 instrument cluster (which is just a slightly modified version of the facelifted cluster from all 2005-2007 C-class cars):
I like the V8, but if you already own a C32 there isn't much point in changing. IMO..
If you decide to keep it for a couple of more years, you should consider modding the car. A stage 2 C32 will KILL a C55 (even one modified with chip, air boxes, headers, and everything else except s/c or turbo). I got 4.2 seconds in 0-60 time more than once in my modded C32, and I've hanged with E55 until about 70 mph then E55 slowly pulled away.
In the end, it comes down to money. Would I trade up for $1? Yes. Would I trade up for $1,000? Yes. Would I trade up for $10,000? Probably not. It's all in the money, and what that money is worth to you.
