Opinion on C32 as daily driver?
Old Mar 17, 2007 | 03:56 PM
RW C55's Avatar
'10 E63 Obsidiant Black; '06 R350 Alabaster White; 05 C55 Obsidiant Black (sold)
yea but i mean, AMG tuned 5.4 vs 3.5.. u would expect 5.4 to be lot more thirsty for gas. My point is, i believe the C32 would have roughly the same, or even better gas milage than the C55, which is not bad at all.
Old Mar 18, 2007 | 03:41 AM
M5CLK's Avatar
'02 C32; '02 M5; '08 328i (US)
Thanks for all the feedbacks guys!! One more question, is all '02 C32 made in South Afraica??
Old Mar 20, 2007 | 11:22 AM
M5CLK's Avatar
Bite the bullet and paid deposit today.. Took it out for a spin but here's where I need help... The steering is extremely light, too light in fact for my taste, it felt just like a S-Class, is it supposed to be speed sensing? And the supercharger is lllllaggy, it's way slower compare to my bro's ex-C230K coupe, it almost felt like turbo lag.. Is it supposed to be this way???
And then, it doesn't really felt all that fast I already had my garage checked it out throughly, everything is said to be in mint condition, could there be any hidden things that won't throw a code but taking away the performance? What should I be looking at when take delivery or maybe how should I be testing it? Thanks!!
Old Mar 20, 2007 | 11:45 AM
jgsx's Avatar
04 C32
I've never experienced supercharger lag on my 32. There are a ton of threads explaining what to look for when buying a used C32.
Old Mar 20, 2007 | 03:37 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
The C32 puts out most of the torque at a higher rpm than the C55. I've found that, unless I'm accelarating from a dead stop, the power takes some time to build. At around 3000 rpm and up the car seems happier.
The S/C will disengage when cruising and re-engages at 2900 rpm or 44% load.
Old Mar 20, 2007 | 04:00 PM
dchao's Avatar
C32 AMG Maserati Coupe GT
No way, with fatter tires and heavier weight than regular W203's, the steering is quite heavy, a lot more heavier than any Japaness cars.
And then, it doesn't really felt all that fast, slower compare to my bro's ex-C230K coupe,
I don't feel lag in my C32 either what you are seeing may be the transmission lag when downshifting. Also you should follow the ECU/TCU reset procedures, if the car has been sitting in the dealership for a while, it might have adopted a very slow driving style.
There is also the ECU/pulley upgrade option.
Old Mar 20, 2007 | 06:37 PM
  #32
amgmark's Avatar
ML63
Do you feel the supercharger kick in at 2800 rpm's? If not you may have an intercooler problem. I don't think the intercooler necessarily throws out codes if it is malfunctioning. The intercooler is a common problem with the C32..
My car feels pretty heavy when turning. I have driven many other C Classes and they all seem to turn very easily, almost too easily. My car is a lot more solid..
Old Mar 20, 2007 | 09:09 PM
  #33
dchao's Avatar
Starting from stand still, push your gas all the way through the kickdown point, you should be thrown back into your seat. If you don't get that sensation, I agree, it is going to be IC pump failure. Without the IC pump, the car will feel like a C320.
