Porting, Polishing, and Cams project
I have decided to drop the car off tomorrow instead of early next week. If MB can have the head off by Monday afternoon, then I'm almost certain I will have the car back before the meet.
in my experience, unless they are brand new, they are usually not very accurate(the ones they use on the dyno)...even then, they will sometimes not pick up accurate readings because of the way they clip into the exhaust...
right, at the dyno that i use, they actually weld in a new 02 bung before the cats so that they can get accurate readings....
you probably don't have enough miles on your car to worry about this...
This will be on MONSTEROUS
C32...
I think you're on your way to reach the 500 hp mark...
Thanks for sharing and good luck on your project...
Watch this video.
http://www.quicktimeperformance.com/Media/WRXVideo.wmv
Here is more info.
http://www.quicktimeperformance.com/QTEC/index.php
Here is more info.
Here is more info.
did you already do this? i would not do it...
1. electric cut-outs are notoriously unreliable, the motors are constantly failing because they can not take the heat produced by the exhaust, especially in a F/I application...
2. since our cars have to have a learning curve in order to take advantage of any gains, you would have to drive around with them open for quite a while in order to realize the full potential...
there is more i could say, but those are the 2 main reasons why i would not do it on this particular car...
When you did your car, did you go through the muffler or open pipes?
-dyno pull
-remove rear cats, then drive a few miles
-dyno pull
-remove front cats (rears still out), then drive a few miles
-dyno pull
with all 4 cats out the car sounded absolutely horrible. The most I saw was a 4ftlb torque gain in mid range with all 4 cats out, but both my peak hp/tq decreased. I saw nothin with just the 2 rears out.
-dyno pull
-dyno pull
-dyno pull
1. See if ANYONE makes, or call some manufactures like Manley, UNDERCUT valves. That is, they cut away some material right at the head of the valve. This alone can often improve flow by about 15%. These are sometimes refered to a TULIP valves.
2. When you change cams, make sure that the new lift/duration will work with the stock valve springs. Otherwise they could float. A condition you DO NOT want, trust me. Depending on the cam profile you may have to change the springs ie increase the spring rate.
3. Look carefully at the intercooler. I have never had my hands on one, so I am just using past knowledge/experience here on other brands. Check carefully at the ports, and ANY casting marks left over. A SMALL improvement could be made here by cleaning them up. It won't make a BIG difference, however every little bit helps.
Sounds like you should have one KILLER AMG when your done.
Keep us posted and GOOD LUCK
PS: I blow a head gasket on my blown stang becsue of an aging fuel pump. It dropped pressure/flow, a little spark rattle later, and ONE GIANT CHOCOLATE MILKSHAKE.
See yeah
Jerry, i appreciate your efforts. reminds me of former member Pierre32///AMG ~ 2 yrs ago.
i will email you my dyno (did it last week) (pdf can't load to site) i made 350 rwhp and i think there is more to come. i can't say enough good things about my supersprint exhaust but i know this is a matter of personal taste.
Anytime! Let's hope for the best with this mod.
I dropped the car off this morning...
my email is jerryt@neo-velocity.com
