Porting, Polishing, and Cams project
Yes I have a before dyno and I will do an after dyno. The "no" comes in based on the fact that I am doing a "staged" upgrade. This stage includes more than just the cams so I will not be able to isolate the gains provided by the cams alone. Part of the reason for this is that the ECU was recently tuned (it is part of this stage) for a number of mods including the cams. Not sure how dyno would look with the ECU expecting the mods and they were not installed - may or may not have made a big difference.
Plus I just don't have the time to run to the dyno everytime I am making a change this round of mods. If I had spread my upgrades out over a longer period of time I would have had more intermediary dyno runs.
As it is I have a baseline dyno from when my car was stock. I also have a dyno with the cooling mods and ASP pulleys. In the next couple of weeks I plan on hitting the dyno again which will include ECU, Cams, LET Pulleys. One of the questions for this next dyno is am I out of fuel - how lean am I running.
jgsx hit the dyno after having the cams installed and I believe he gaind 17hp on a mustang dyno. His results are posted earlier in this thread.
P.S. I only seen one dyno on the following:
1. Shriek Cams(JGSX)
2. LET headers(1FASTC32)
There might be more but this is what I seen. AMGJerry had cams on and other mods that could create more gains from anything he installs when he installed the LET pully so his dyno would not really say numbers based on the average of non-cam users. I am trying to learn more of the possible gains these products could create but honestly since our cars don't come equal within a range of 2 hp. Its hard to compare the actual gains. I have learned that you can't believe what the websites say when it comes to power gains but these forums could provide answers. The best money you spent was doing a baseline dyno first cause even if the gains aren't much you can see that the car has gained either way. I recommend using the same dyno for your last dyno also cause it will represent best since you already been there. If with all the mods you are not satisfied with the numbers you can always go to a dyno machine that shows more but always keeep in miind that as long as the gains are increasing that you invested more on the wise side.
**BY THE WAY IF YOU SELL THE ASP PULLIES JACEK9478 MIGHT BE INTERESTED**
I have been to a couple of dyno days and both the SLK32's and the E55's dyno'd very consistently. If I remember correctly the SLK32's and E55's all dynod with no more than a 6hp or so variance.
It was different dynos so keep that in mind but with the addition of the pulleys and cooling mods I gained 37rwhp. I was forced to use different dynos due to the location of the original dyno.
My feeling is that the numbers are what they are. I am not interested in playing games by hitting different dynos.
Merry X-Mas everyone. You guys are my second family and I wish you all the best. Thanks for supporting me during my "crazy" moments.
God bless!
