Porting, Polishing, and Cams project
Old Aug 16, 2007 | 03:43 PM
  #451
Eurocharged Rick's Avatar
SPONSOR
Originally Posted by 430
I remember there was talk of running a 192mm pulley. Not sure how much boost that translates into.
What size Pulley was Vadim running when he started to see the SC clutch slip?
I am very interested in this pulley. I have upgraded my cooling with a much larger secondary heat exchanger adding ~1 gallon of coolant to the system. Additionally I have added a CM90 pump. That pump is a very tight fit on the SLK32.
I am currently running the ASP pulley's and was considering going back to ASP to build me a larger Crank pulley to up the boost.
This looks like a better option. Do we have any pricing?
Very interested in the before and after numbers on Erics install.
Vadim was running 192mm with clutch slip, this one should not cause any kind of slippage...
Old Aug 16, 2007 | 04:01 PM
  #452
430's Avatar
430
SLK32
Hell, lets strenghten the SC clutch and move on up the bigger pulley
What is the pricing on your new pulley? PM me if need be.
Old Aug 16, 2007 | 04:02 PM
  #453
sales@eurocharged.com's Avatar
SPONSOR
C63S
Awesome! I use carship too.
Are you using the numbers in that thread to calculate your boost? With the Renntech Pulley carchip showed I was at 30.3 PSI. With the Leading Edge Motorsports Pulley, I'm at 32.8 PSI.
I thought it was:
30.3 - 14.7 = 15.6 PSI - Renntech Pulley
32.8 - 14.7 = 18.1 PSI - Leading Edge Pulley
Please help me understand this software.
See pic
Old Aug 16, 2007 | 04:04 PM
  #454
SPONSOR
C63S
The S/C is spinning within 2000 RPM of redline. I wouldn't go any larger...
I know it sounds like alot, but with a near 20000 RPM limit, 18k is mighty close.
Old Aug 16, 2007 | 04:28 PM
  #455
430's Avatar
430
SLK32
I was 3/4 joking. Strenghening the SC clutch is probably a PITA.
I am very interested in seeing the power this pulley puts down compared to the RENNtech or stock or whatever the baseline is going to be.
Old Aug 16, 2007 | 04:31 PM
  #456
neihouma's Avatar
02 C32 AMG sold!
I thought it was:
See pic
I'm still learning myself,
Last night I went to Moroso to run some 1/4 times, and look what data
Carchip Pro logged for me.
A bar in psi / lbs = 14.50326, while the exhaust parameters are 14.7
Old Aug 16, 2007 | 04:38 PM
  #457
neihouma's Avatar
02 C32 AMG sold!
Also, I changed my settings, Hard Acceleration is set on .75G & Extreme
Acceleration is set on .99G
Take note on the 5th run I went to pick up my slip and drove out of the track
to the gas station.
Old Aug 16, 2007 | 04:58 PM
  #458
MRAMG1's Avatar
S600, GL450, GLC 43
[QUOTE=neihouma;2371014]I'm still learning myself,
And the times were?
See yeah
Old Aug 16, 2007 | 04:59 PM
  #459
neihouma's Avatar
02 C32 AMG sold!
Originally Posted by MRAMG1
And the times were?
See yeah
Not worthy to post, slower than stock.
Old Aug 16, 2007 | 05:39 PM
  #460
rlee02135's Avatar
2004 C32 ///AMG
so...who's up for making a smaller SC pulley to go along with this
Old Aug 16, 2007 | 06:12 PM
  #461
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
so if we already have the evosport pulleys that means we gotta change it back to stock and run this main pulley right?
this sounds very tempting.
Old Aug 16, 2007 | 06:25 PM
  #462
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
Let me just say that one of my projects involves the SC pulley...I have been actively working on this one and hopefully will have some news to release soon...
Old Aug 16, 2007 | 06:27 PM
  #463
MB_Forever's Avatar
E63 P30, CL500 Sport
I wish I still had my car, I would've installed this new pulley in a heart beat.
Eric and Jerry, keep up the good work, I'm learning a lot from all this...
Old Aug 16, 2007 | 07:44 PM
  #464
SPONSOR
if you are going to switch over, then i would suggest putting the stock setup back on and then running the Leading Edge setup...that way you can sell your evosport pulleys as a set...
Old Aug 16, 2007 | 08:21 PM
  #465
SPONSOR
C63S
I agree 100% By swapping the pulleys, you will in turn have a new set on your car. Nothing like fresh bearings.
Old Aug 16, 2007 | 08:26 PM
  #466
SPONSOR
C63S
On a side note, there is another advantage to the LET Motorsports Pulley. The pulley is a 3 piece design with a removable hub. Look at the pics...
This means that you can install a 185mm pulley and if you decide to upgrade that even further, all you have to do is remove the belt and remove the pulley from the hub, not the car. This is done by removing the HEX bolts from the hub. Think about it...you can upgrade your pulley later on without having to break the crank bolt. This means that anyone can do the install in about 20 minutes.
Or, if you want to put your car back to stock for whatever reason, you can get a stock sized pulley for the hub.
Not to mention the weight benefits! This pulley only weighs 4ozs more than the stock pulley!!
Old Aug 16, 2007 | 08:30 PM
  #467
SPONSOR
C63S
to the gas station.
What pulleys do you have on the car?
I double checked my numbers and you are making more boost than me with the larger pulley.
Looks like I'm now in need of more boost!
Old Aug 16, 2007 | 08:31 PM
  #468
SPONSOR
C63S
I have an extra one that I could lend out for R&D. However, I must admit that I don't think it's feasible.
Old Aug 16, 2007 | 08:35 PM
  #469
SPONSOR
ASP Pulleys...
Old Aug 16, 2007 | 08:55 PM
  #470
neihouma's Avatar
02 C32 AMG sold!
ASP Pulleys...
Erick got it right!
I can't explain why the boost spike, anywhere from 25psi to as high as 35psi
(on other logs).
I've tried using this CarChip Pro on my 03 Evolution Lancer and it won't read
the Intake Manifold Pressure, but I know I'm running 1.5bar or 22psi.
I'm gonna send Davis.net a email tonight when I get home, I hope they can
explain why the boost spike and can't read off my EVO8's boost readings.
Old Aug 16, 2007 | 08:56 PM
  #471
Its very feasible. I have an extra one we used for r&d. Like I mentioned briefly, I took a different approach to creating power. I will have more news soon.
Old Aug 16, 2007 | 11:02 PM
  #472
jgsx's Avatar
04 C32
I have an ASP pulley up for grabs PM me if interested.
Old Aug 17, 2007 | 12:09 AM
  #473
c32used's Avatar
LET C32 2002
OK, we got most of the work done this weekend. I wanted to thank everyone for coming by the house and helping out.
Thanks to:
1FastC32 - Dude flew in from Houston to help me out!
P_Rossi - Thanks for lending a hand....I know you had a late Friday!
C32Used - Thanks for clearing your schedule and making time to come by!
Vadim - Thanks for answering the phone!
_PTE_ - The thermostat works great!
I'm sure my neighbors thought I was running an MB dealership most of the day.
Here is what we got done:
1. Larger Heat Exchanger - Done! This thing rocks!!
2. Evosport Sway bars - Doing these today.
3. Ported / Polished Supercharger and Intake Plenums - It looks awesome!!
4. New IAT sensor - Done! easy replacement
5. Transmission Flush with new filter and fluid - Done! easier than I thought
6. Porterfield R4S Brake Pads - Decided to take it somewhere to get done.
7. Secret Mod that will be released soon by 1FastC32! - OMG was this a pain in the ****.....will have dyno numbers soon.
8. C&R Racing Radiator - Not done Didn't make it to me in time
9. Modded Thermostat - Thanks _PTE_ for hooking me up! Easy to do with the car apart.
We only ran into a few problems. Some where easy to overcome, but there were a few that took a bit of thought.
I ended up not using the ported intake plenums because MB was right, they were warped. After we swapped intake plenums, the car ran perfectly. I had a rough idle for a few minutes last night, but for the most part, it seems like a different car. The car pulled harder than ever on the way to work this morning, and the rough idle is almost nonexistent today.
We took a few pics and I will try to get them posted up later.
It was my pleasure to argue with wife to see the incredible work you guys were doing! as some of you might know I am divorcing soon so it was fun to ignore her to see this progect. It was a pleasure to meet Erik(1fastc32) and I was very impressed by his knowledge of engines and see again Piere(P_Rossi). I ordered a CF lip from Eurotek today and can't wait to have it installed so see you in about a week and a half Jerry. By the way guys Sam the guy who came with me ownes a house in Michigan 5 minutes from Lake Michigan so maybe we can plan a trip up there one day its 3 bedroom with full to king size beds so we can fit 6 people easy and like another 8+ in sleeping bags so lets go have fun!
Its kind of hard to feel power due to my stroke but I feel the C32 and can't wait to test drive Jerry's car one day when all is done. Hey P_Rossi if you are ever in my area again you are welcomed to stay at my house so you don't have to stay at a hotel or take that long trip to Aurora ok.
Old Aug 17, 2007 | 12:57 AM
  #474
rlee02135's Avatar
2004 C32 ///AMG
will we need a re-tune with the Leading Edge Pulley?
Old Aug 17, 2007 | 06:18 AM
  #475
MRAMG1's Avatar
S600, GL450, GLC 43
Sorry to hear that
Good luck sorting everything out, and THANKS for ALL the GREAT info
See yeah
