arghh battery messed everything up. please help.
my battery was completely dead after being in europe and not driving my car for 5 weeks...
yesterday the alarm was going off, but a much less loud alarm...
I disconnected the battery and it was still going off...
I reconnected the battery and with the new battery used jumper cables, as soon as i connected the last cable, the real alarm went off, that's when i used the key fob to lock and unlock the doors, disabling all alarms...
then i changed the battery
after a few minutes, the car cranked
but it says display faulty, visit workshop...
the auto windows didn't work, so i lowered all of them, help them down for two seconds after they were lowered, and then they worked, same with the sun roof, the CD player didn't work, ejected the cartridge, and now it works...
turned the wheel to the left and right multiple times, no go, still have the error messages...
I got everything to work, except for the back sun blocker, turn signals, emergency flashers....stuff like that...
anyone have a clue what I can do?
besides getting raped at the Stealership?
thanks
Plague
next step is to have the rear SAM checked out...if you can find someone with the star diagnostic system besides the dealership, then you can find out very quickly if it is the rear SAM or not...but my guess is that it probably is going to be that from the symptoms you are describing...
you could always order one online and replace it yourself if it doesn't turn out to be just some blown fuses...
i will look around for a rear SAM and see what i can find...
https://mbworld.org/forums/c-class-w203/115277-list-faults-occur-after-disconnecting-battery.html
that is, unless the charge/jump/boost produced quite a surge for some
reason. another thought - just disconnect the battery again and wait
a few mins and hook up again. perhaps the car just hocked a lugee and
subsequent disconnect will jog it loose. anecdotal, but it is a proven
technique once in a while. of course, you'd have to deal with the memory
feature settings again
i only checked the little colored ones, not the big socket ones...
disconnected the battery and reconnected it...
no go
how much does a rear SAM cost?
thanks again
this sucks
Plague
Put the old (dead) battery back in the car.... call 1-800-4-MERCEDES, tell them that your battery is completely dead. A technician will come and replace the battery.... let him handle all the reset and everything. Calling the roadside assistance is a lot cheaper than going to the dealer as they won't charge you at all for labor.
I got my E's battery replaced for only $150.... while at the dealer, I was quoted $225 ($150 for battery + $75 for labor
). Plus, they do it at your house.... Good luck.
I had pep boys install a new battery and after the install the "SRS" light came on.. and now I have an error message.
everything works and I do have a turn signal light error and license plate light error as well.
car is running fine... except for those errors.
i have been to lazy to look around for the problem.. but I guess its time.
I'll post my findings...
