Replaced SC Clutch bearing last night ~ pics/video
#101
You don't need to take the snap ring off. It's a lot easier when the engine is completely cold. You need to take it off at an angle. Try wiggling it up and down while pulling out. It should slide off a few millimeters each wiggle.
#102
02 C32, 03 ML55
Cold engine is a great tip. Thanks.
#103
Super Moderator
Zeppelin’s technique worked perfectly.
Upon reassembly, noticed the pulley-to-snout clearance was too large.
Removing one of the three original spacers enabled measurement within specification.
Note each has a different thickness, likely to maximize available adjustability.
The pleasant result was reduced engagement “chirp.”
![](http://i209.photobucket.com/albums/bb196/splintersAMG/C32PulleyShims.jpg)
![](http://i209.photobucket.com/albums/bb196/splintersAMG/C32SuperchargerPulleySnout.jpg)
![](http://i209.photobucket.com/albums/bb196/splintersAMG/C32Pulleygauge2.jpg)
![](http://i209.photobucket.com/albums/bb196/splintersAMG/C32Pulleygauge1.jpg)
![](http://i209.photobucket.com/albums/bb196/splintersAMG/C32ClutchSpecification.jpg)
#104
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#105
2003 CL55 AMG
wellll im sad to say that i ordered that bearing and it was way too small. i finally realized that my car i different... i drive an 03 CL55 and im not exactly sure on the measurements on my bearing. there is 40X62X20.625, 40X62X24, and 40X66X24 but im not 100% sure on which one i need. the one i bought was 30X55X23 and it was super small
#106
+1
#108
Super Moderator
Their respective dimensions are ostensibly designed for minimal (hand) pressure requirement upon installation at workshop temperature.
Note the two tend to become a mild interference fit during normal operating temperatures.
