Brakes/Rotor Replacement for C32's
Old 04-24-2007, 05:41 PM
FQC32's Avatar
2002 C32 AMG, 1997 C5 Corvette (sold)
Tried looking, but couldn't find a thread on a do-it-yourself brake job for C32's. Wondering if someone can help me out with some instructions. I'd like to eventually replace pads and rotors, but for now just want to do pads. How easy is this job? Thanks in advance.
Old 04-26-2007, 03:45 PM
auxo's Avatar
03 C32AMG, 05 ML 500, Ducati 998S
Follow this procedure
Hello,
I just did front rotor/brake pad/brake lines replacement on both my C32 and ML500 (literally 3 days ago). This link is from the ML (163) Forum, but the procedures are 98% identical. Try it out, it worked for me.
http://www.petefagerlin.com/ML/brakes.htm
Old 04-26-2007, 04:00 PM
Fifth Ring's Avatar
C32 AMG
If you've done pads before, it's really easy. Once the clip is off (see post above) the slip out the back. The tricky part (as with any pad replacement) is getting the pistons retracted so the new pad slips in.
PS: I have to put in a plug for EBC RedStuff Ceramic pads. I'm on my second set and they've taken enormous abuse without fading or deteriorating.
Old 04-27-2007, 05:30 PM
FQC32's Avatar
Originally Posted by auxo
Hello,
Great! Thanks very much. I'll give it a shot.
Old 04-27-2007, 05:31 PM
FQC32's Avatar
Ok thanks. Maybe I'll give EBC a try instead of Porterfields.
Old 04-27-2007, 06:53 PM
Prasith32's Avatar
Hi,
I haven't been on here in a really long time because I haven't used my C32 at all but I am back as I am either going to mod it up big time or sell it.
Anyways here is a thread with procedures for changing brake pads from a while back. If you have the C32 it should still hold. I plan on changing mine soon too. I have always been partial to the R4E's but they do squeak a good amount when it is cold.
https://mbworld.org/forums/c32-amg-c55-amg-w203/77203-replacing-brake-pads.html
Hope that helps.
Old 04-27-2007, 07:02 PM
Fifth Ring's Avatar
C32 AMG
Good feedback on Porterfields too. Can't go wrong.
Old 04-27-2007, 07:15 PM
FQC32's Avatar
Originally Posted by Prasith32
Hi,
https://mbworld.org/forums/showthread.php?t=77203
Hope that helps.
Thanks!!! The feedback on this thread will definitely help me out.
Old 04-28-2007, 05:33 PM
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
Hi,
Hope that helps.
wow a voice from the distant past! thought you moved on. hey, if you are down my area (i actually have to be in hartford for work next week) feel free to drive my car. i remember you were one of the first guys to start tracking the c32.
Old 06-15-2009, 10:43 AM
eclipsed's Avatar
2002 C32 amg, 1998 328i
xtra info please
reviveing a old post. Im doing mine today and was warned to turn off some system to keep the pistons from shooting out? something about they are still under pressure? insight would be great.
Old 06-15-2009, 11:48 AM
Super Moderator Alumni
ScottW911's Avatar
a C32 AMG & S-Works Tarmac
Pistons shooting out? No. Just follow the steps laid out in the link from Prasith32. I did it and everything worked out great.
Old 06-15-2009, 11:55 AM
MRAMG1's Avatar
S600, GL450, Audi A5 Cab
Only the W211 E55's have the electronic pump that you MUST disable or indeed the pistons will shoot out. C's don't have this problem my friend.
As was stated above, if you EVER plan on tracking her, the EBC redstuff are the cats meow
Ceramic to boot, aka NO dust, okay very little.
See yeah
Old 06-15-2009, 10:56 PM
eclipsed's Avatar
Thanks for the info. Using Akebono for everyday driving.
Old 06-15-2009, 11:40 PM
c32used's Avatar
LET C32 2002
Thumbs up
Hello,
Thanks for this link I may do rotor and pads myself with a friend.
Old 06-15-2009, 11:44 PM
MBworld Guru
FrankW's Avatar
white and whiter
there's a good write up by mig888 in the w203 forum as well since he has the full 32/55 brakes.
Old 06-16-2009, 03:01 PM
c32used's Avatar
LET C32 2002
Can u please post link if you could I will be busy today
Old 06-16-2009, 04:10 PM
MBworld Guru
FrankW's Avatar
white and whiter
here you go. https://mbworld.org/forums/c-class-w...rthoughts.html
Old 06-16-2009, 04:25 PM
c32used's Avatar
LET C32 2002
Thumbs up
Thanks Frank
Quick Reply: Brakes/Rotor Replacement for C32's
