Steering and suspension 'creeks'
Has anyone else experienced this? I'm not complaining since the dealer was able to fix the noises and it was all covered under my MB-CPO warranty - just curious if this is common for W203s.
Apparently the bushes have been redesigned with end caps that stop them leaking or drying out, IIRC. Someone else may be able to ellaborate further.
See: https://mbworld.org/forums/showthrea...ighlight=clunk
and: https://mbworld.org/forums/showthrea...ighlight=clunk
Any advice on which fasteners to check first would be most appreciated. Thanks!
The sound is coming from within the cabin, right behind the actual steering wheel on the column. It is a hard sound to describe, but its like there is a metal cable rubbing on the inside of the steering wheel when it's turned. More high pitched, ratcheting sound... not a moan. Looks like I'll be taking it back to the dealer. This time I'm telling them to replace whatever's broken and to not just 'tighten' the damn thing. Argh!
Sounds similar. The ratcheting noise happens the first 1/4 turn of the wheel in either direction for me. I am taking it back to the dealer next week and will report back here on what they find.
Suspension noise: Turns out there were two bolts (one on each side, left and right) of the swaybars that were seized. They drilled out the bolts, replaced them with new ones and installed new bushings. The creaking noise from the front suspension is gone!
Steering wheel noise: The steering wheel 'ratcheting' sound when turning was fixed by replacing the steering box.
All work was covered under my MB Star Warranty at no charge.
For the record, all work was done at Mercedes-Benz of Westmont (western suburb of Chicago). Friendly, fast service. My best experience yet with a dealer service dept.
I have had the same problem, with squeeks which were sorted out at the dealer under warranty that turned out to be the bushes which were replaced... however i have noticed that when reversing slowly down my driveway as i go over the driveway lip and the car very slightly rocks side to side in the front suspension there is the harder groaning noise if i can describee like that! which i think might be a loose bolts issue but when i first reported the issue at the last service they just fixed the bushes and could not find anything else. susppose now they need to go in and dig alittle deeper.
If you are still under warranty, I would encourage you to keep going back to the dealer. In the process of them troubleshooting my problem the dealer replaced virtually my entire front suspension so at least I shouldn't experience any more suspension issues.
Hey, gotta look at the bright side.
