Header Project...
Old Nov 15, 2007 | 07:54 PM
  #151
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
Originally Posted by 1FASTC32
it is not any louder than stock, it just flows much better...
.. waiting for result
please PM me because I'm interested in a special replacement for 55
Old Nov 15, 2007 | 09:13 PM
  #152
SteveL's Avatar
C43, SLK32, CLK63 Black Series
Originally Posted by SteveL
Diff is finally done. Dyno is tonight. I'll post the results. Erick, do you have results from your headers yet?
Unfortunately the dyno got delay until tomorrow at noon. Another car was having some problems on the dyno so we got bumped to tomorrow.
Old Nov 16, 2007 | 11:07 AM
  #153
Eurocharged Rick's Avatar
SPONSOR
got bumped as well...hopefully soon, will keep you posted...
Old Nov 16, 2007 | 09:22 PM
  #154
SteveL's Avatar
Posted same on benzworld/r170 forum. Now I wish I had of resolved my A/F ratio problem before having the headers built, see below.
Dyno results...
Hmm... complicated. The showed a gain but the gain is limited because the A/F ration actually got worse. It does make some sense. The car is flowing more air but the ECU is not providing enough fuel. Renntech is going to take the car on Monday and do some tuning to add some fuel. However, for a real apples to apples comparison, I would have had to tune the ECU before the changes as it was running lean before the changes so the car might have made more power if I had it tuned to add more fuel. Of course, that is no longer possible.
The gain was across the whole power band which is nice and torque increased more than hp which makes it more usable power. The real test of the headers would be on a stock 32 with before and after dynos.
Here are the charts... I should have more next week when Renntech tunes the ECU. After the tune, we'll dyno again on the same dyno to get a better comparison with the dyno before the changes but as I said, it will still not be ideal.
Attached Thumbnails Header Project...-floored-power.jpg   Header Project...-floored-f.jpg
Old Nov 17, 2007 | 01:47 AM
  #155
SPONSOR
Dyno results...
Looks like some nice gains already steve! i have an appointment for Monday morning first thing...i will let you guys know what happens!
Old Nov 17, 2007 | 11:45 AM
  #156
sales@eurocharged.com's Avatar
SPONSOR
C63S
Dyno results...
Steve - Your A/F Ratio seems fine. You want it to run a little lean for the extra power. If they were using an O2 sensor mounted in the muffler, then your actual A/F ratio would be 12.5, not 13.
Your A/F ratio looks just like mine.
Old Nov 17, 2007 | 09:05 PM
  #157
SteveL's Avatar
Jerry, I'm not so sure. As part of the changes, I had the spark plugs changed to NGK BKR8EIX plugs. My previous plugs showed "pepper" on the ceramic of the old plug indicating detonation. If the car is detonating, the ECU will take out some timing which will decrease output.
Old Nov 17, 2007 | 10:20 PM
  #158
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
...If the car is detonating, the ECU will take out some timing which will decrease output.
That’s true.
I’ve seen knock retard readings approaching -24 degrees at WOT. Did your dyno operator log IATs and timing?
Old Nov 17, 2007 | 10:42 PM
  #159
SteveL's Avatar
Originally Posted by splinter
That’s true.
Not sure. I'll ask. Renntech will check when they get the car on Monday.
Old Nov 18, 2007 | 12:14 AM
  #160
SPONSOR
how did the car run with those plugs?
Old Nov 18, 2007 | 03:43 AM
  #161
SteveL's Avatar
Which plugs, old of new? On the old plugs the car ran fine. Chris tells me that the car is running well on the new plugs as well. Idle was pretty smooth on the stock plugs. I haven't driven the car with the new plugs yet.
Old Nov 18, 2007 | 08:52 AM
  #162
SPONSOR
i was referring to the new ones...i am running the 7 series currently, i did not think the car would like the 8 series...it is 2 heat ranges colder from stock...thanks for the info!
Old Nov 18, 2007 | 10:30 AM
  #163
SPONSOR
C63S
Steve, trust me, you are preaching to the preacher on this one. I've sent my ECU to Renntech more times than anyone else and the lean A/F ratio is still there. I've tried using the nitrous nozzle to add a little more fuel and this only resulted in less power.
I consider my car optimistic, it has high hopes that all systems are functioning well and adjusts base maps accordingly. If, the ECU finds that a single parameter is incorrect, it will pull timing / fuel.
I bet you didn't know that if your IAT's are 95 °F - 112 °F, the ECU will pull 3.5° of timing. If your IAT's are 113 °F - 146 °F, the ECU will pull 6.3° of timing. If your IAT's are 147 °F+, the car will pull 9.5° of timing! This only happens during full load situations....such as on the dyno. I was monitoring my car at the track and my IAT's only reached 95 °F once in the day. Needless to say, I was running 12.5's all day long and ran a personal best that day of 12.4.
So, if your IAT's are sitting at 113° F + during runs on the dyno (like most of us), then your ECU will pull at least 6.3° degrees of timing.
I would be willing to bet that your car is detonating due to cooling issues.
I'm only trying to help because I have been down this road, many times over. Get yourself a datalogger so you can pinpoint when the timing is being pulled.
What are your cooling mods? Is your IC circuit still shared with the engine coolant?
Old Nov 18, 2007 | 12:10 PM
  #164
SteveL's Avatar
Jerry, thanks for the details.
Before this round of mods, I still had the stock cooling system so maybe that is why there was previously some detonation on the old plugs. With this round of mods cooling should be more than adequate. We added a much larger intercooler, a remote reservoir in the the trunk and 2 Johnson CM30 pumps.
The dyno tuning with Renntech is not going to cost to much so we'll see if I can get any more out of the car with some tuning.
Old Nov 18, 2007 | 04:29 PM
  #165
SteveL's Avatar
I have another simple question, what kind of gains are people getting with headers on C32s? Any difference between gains on a stock C32 vs gains on a pulley/ECU/etc. C32? Thanks.
Old Nov 18, 2007 | 05:56 PM
  #166
SPONSOR
well, i was doing a couple of things to get the car ready for the dyno tomorrow and discovered that the intercooler is leaking...
i have the supercharger pulled off the car already and got everything cleaned up again...getting ready to leave to go to something that we already had scheduled tonight...
hopefully i can get the car put back together and get everything ready for the dyno in the morning...it is going to be a long night...
Old Nov 18, 2007 | 09:08 PM
  #167
SteveL's Avatar
Good luck getting it back together tonight. Your dyno will help know what to expect. I would have still thought that there have been enough C32s with headers that someone would have done a before and after dyno.
Old Nov 18, 2007 | 09:43 PM
  #168
SPONSOR
i put the evo headers on my car and did not gain anything...
putting the car back together right now...
Old Nov 18, 2007 | 10:10 PM
  #169
splinter's Avatar
Super Moderator
...discovered that the intercooler is leaking...
Whoa, sorry to hear about that. I suspect the entire C32 contingent will be facing the same task eventually.
Kindly let us know how it goes…
Old Nov 19, 2007 | 01:07 AM
  #170
SteveL's Avatar
Interesting.... any idea why? Is the stock system good or are the cats too restrictive to see a benefit from headers? What kind of gains are you expecting with your headers?
Old Nov 19, 2007 | 09:19 AM
  #171
SPONSOR
Thanks! got it back together and it is running very well! getting ready to head to the dyno! wish me luck!
Old Nov 19, 2007 | 11:55 AM
  #172
SPONSOR
i just posted the results in a new thread, check them out!!!
