Newbie questions for the 2006 C55 owners
1. How do you turn off the Automatic Speed Leveling on the stereo with Command
2. How do you turn off the voices within Navigation?
3. How do you change the voice within Navigation?
4. What is this extra antenna on my car? Navigation? Sirius?
1. Dealer
2-3 No idea.. mine doesn't have Navi
4. On on your roof is for Sat radio / navi.. One one ur rear window is for ur reg radio.. i think
2) turn the navigation off.
3) purchase a European Comand
4) antenna on roof is Sirius
Euro Comand has a British Voice.
There is also a GPS antenna which can be under the glass next to the puppy dog tail, in the hockey puck, or taped to the inside the dash pad above the instrument cluster. Depends on where the COMAND was installed.
With the nav speaking you can hit repeat and then mute. If you hit repeat and toggle the volume that will change the level of the nav volume
If you hit repeat and put it all the way down when it gives you an instuction - it will lower the radio without saying anything and drive you crazy- so hit repeat and mute
BTW the radio antennae is in the front windshield - that's why it says it on the glass-
The tail is the tele and teleaid **** and maybe the gps I dunno.
So the antenna on the roof IS NOT FOR SIRIUS satellite radio, MOST W203's have this, C230's, C240's, C320's, C350's, C32's, C55's - without Sirius radio installed. So if you do not have this, you will notice you do not have TeleAid. The Sirius "antenna" is more like a little black-box, you'll find the same thing at Best Buy, it's not a 'Mercedes' made product.
That's the only question I can comfortably answer and know is correct.
Tee_Tz.
Tee_Tz.
Tee_Tz.
... well yes, the hockey puck is Sirius and the Stick is TeleAid.
