C32 did not Start (No electrical power)
Old Aug 13, 2007 | 01:45 PM
TopGun32's Avatar
This is the 2nd time in the last 3 months I have tried to start the car and no electrical current available.
The first time, I jumped the car battery and unplugged my drivers side seat module and everything was ok. I knew it was the seat problem.
This time the car sat in the garage for 3 days and it would not start. I jumped the car battery and unplugged the passenger seat module. But I'm not sure if that is causing the problem.
Anybody has a guess what else can be drawing current from the battery?
I'm driving with a car that can move the front seats unless I plug in the seat modules. I just love all the electrical issues with this car.
Old Aug 13, 2007 | 02:06 PM
///AMG4EVER's Avatar
CLS55 Designo 030
From is my experience, unplugging the seat modules was not sufficient. My car will literally die every morning.
The symptons:
1) Nav CD kept spinning even when the car turned off.
2) Seats were not in the correct position when entering the car after a while.
3) A bunch of electrical malfunctions after each jumped start. The rear sam blew up by jumped starting the car too many times.
I ended up replacing both seat modules, the rear sam and a new battery to fix the problem. It's been over a year and no problem so far.
Good luck.
Old Aug 13, 2007 | 06:23 PM
TopGun32's Avatar
tell me about the SAM...
i'm clueless what you mean?
do you have a part number or receipt?
thanks for you help.
Old Aug 13, 2007 | 06:37 PM
STLTH_AMG's Avatar
C63, SLK55
Did you change ur alternator recently? Did you get any alternator error msgs on ur display? Mine just went out all of a sudden on the same day it started complaining about the alternator, the car completely lost power!! I had to tow it on a flat bed after dinner on a Saturday night to the dealership!! They replaced the alternator which seemed to put power back to the car! I also have the seats unplugged but I probably put a lot of stress on the alternator in the past from the multiple times I had to jump-start the car before I figured it was the seats causing the battery drain. You might have a fried alternator if you had to do multiple jump-starts to the your car in the past as well!
Old Aug 13, 2007 | 08:04 PM
Expat's Avatar
2002 C32
I've had both seat modules go within 3 months of each other, now I just drive around with them unplugged, symptoms were similar but it's fine now (as long as I don't need to move the seats!)
Old Aug 14, 2007 | 02:26 AM
Eurowow's Avatar
Amg C32
tuff
Same problem with my C32, i think all C CLASS should have a recall on this issue.
Old Aug 14, 2007 | 07:18 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
I guess this is stating the obvious, but with your car being 5+ years old and 7x,xxx miles, are you sure you haven't just reached the end of the battery's useful life?
Old Aug 14, 2007 | 09:39 AM
CLS55 Designo 030
The rear SAM is basically the fuse box in the trunk. PN: 203-545-34-01.
I had to replace it because I jumped started the car too many times.
If you change the battery w/o fixing the problem, the car will be fine for 2-3 weeks max. Then the problem will come back. I would start by replacing the seat control module that has the current draw.
211-870-4726 - Driver's module
211-870-4626 - Passenger's module
Old Aug 14, 2007 | 11:03 AM
STLTH_AMG's Avatar
C63, SLK55
Is this an easy DIY? can the SAM and seat modules be changed without any complicated tools?
Old Aug 14, 2007 | 12:09 PM
TopGun32's Avatar
i will have it checked with my local mechanic. Good point.
Old Aug 14, 2007 | 12:10 PM
TopGun32's Avatar
good point.
Replaced battery back in January this year.
Old Aug 14, 2007 | 12:11 PM
TopGun32's Avatar
awesome!!
Thanks for the info..life saver once more.
Old Aug 14, 2007 | 01:27 PM
CLS55 Designo 030
According to my receipt, the rear sam needs to be programmed.
I think the modules can be replaced w/o a problem. PM the guru Sunman to make sure.
Old Aug 14, 2007 | 01:30 PM
CLS55 Designo 030
awesome!!
No problem man. It took me forever to figure this out. The dealerships are so incompetent and have no clue when it comes to diagnose a problem.
Hope you can get your issues taken care of soon.
Old Aug 14, 2007 | 03:22 PM
Expat's Avatar
2002 C32
Just to emphasize the warning, there's a known problem that if have your keys in the ignition when you connect another car/battery to jump start the car it blows the rear SAM
Old Aug 14, 2007 | 03:26 PM
Expat's Avatar
2002 C32
Does anyone have a good source/prices for these modules?
Old Aug 14, 2007 | 03:55 PM
CLS55 Designo 030
Expat - Duvals and oempartsdirect are just best bet.
