Slight performance decrease at times.
Old Aug 18, 2007 | 01:54 PM
pointman's Avatar
a car that can't do the throttle reset.
04 C32, low miles. Lately I have been noticing that the throttle response isn't as strong as usual. When I push the throttle, normally the car moves strong and confidently. But lately at times it is SLIGHTLY sluggish. Definitely not limp home mode or anywhere near that bad. Very slight. Then thru the course of the drive it will return to normal.
I know it seems vague, but I think that if anyone understood it would be a fellow C32 driver. And no, I am not getting any error messages.
Old Aug 21, 2007 | 11:57 AM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Sometimes my c36 does the same thing. Especially when its heat soaked.
Old Aug 21, 2007 | 12:57 PM
pointman's Avatar
I had a C36 and a C43. Neither of them exhibited this weird trait.
Old Aug 21, 2007 | 01:10 PM
jacek9478's Avatar
C32 AMG
mostlikely all you need to do is reset your ecu.
While you drive ECU learns and adopts to your driving style.
To reset ECU just turn ignition on ( do not start engine ) and depress throttle ( just floor it ) hold for 5-10 seconds and start engine. Your car should get the edge back.
Old Aug 21, 2007 | 04:22 PM
pointman's Avatar
Interesting. Do I hold the throttle down while restarting?
Thanks.
Old Aug 21, 2007 | 05:00 PM
Magician's Avatar
2003 C32 AMG
Thanks.
No, let off the gas after the 5-10 seconds, then restart
Old Aug 21, 2007 | 06:07 PM
pointman's Avatar
Thanks. Just did it. Hoping it worked.
Old Aug 21, 2007 | 10:11 PM
1FSTAMG's Avatar
C32 AMG - RIP :(
Let us know if it works or not.
Old Aug 26, 2007 | 01:47 AM
pointman's Avatar
Well, it didn't do anything good.
The other day I lost power. On the highway... cruising around 65 and floored it. NOTHING. Car didn't rev, and it didn't pick up speed at all. It was like I wasn't hitting the throttle. Something is completely fubar.
Old Aug 26, 2007 | 04:27 AM
Slater126's Avatar
2002 C32, 2011 VW GTI
That's probably the transmission. These cars have a sort of "adaptive" driving program where if you drive slow for a time (like in heavy traffic) the transmission gets slower and doesn't shift as quickly. That's probably what you're experiencing. Happens to me all the time living in a congested urban area. No way to avoid it other than shifting manually.
Old Aug 26, 2007 | 07:49 PM
pointman's Avatar
Definitely not the case. I manually dropped to third at over 60 mph, and the car still didn't move.
Old Aug 27, 2007 | 10:31 AM
jacek9478's Avatar
C32 AMG
In this case look into your I/C pump.
Drive your car hard for few minutes, if you loose power and after another few minutes power is back- classic symptopms of failing I/C pump.
easy to fix DIY, almost impossible to convince dealer to repair it.
Good luck,
Jack
Old Aug 28, 2007 | 12:13 AM
pointman's Avatar
Interesting. Thanks. The tech told me he is thinking "water pump".
Old Aug 28, 2007 | 11:16 AM
Bif powell's Avatar
2002 c32
If it's a complete loss of power, it's probably the intercooler pump. If it's 'slight' then it's probably just the fact that the transmission is deciding to go into a higher gear and bogging. If you manually shift it, it should rock and roll. If you manually shift it and it's totally sluggish, and this behavior is complete or intermittent, I would suspect the IC pump. It just happened to me, so your last couple posts seem to describe what I've been feeling as well.
Old Aug 28, 2007 | 12:25 PM
Hazy1's Avatar
'03 E55
When the IC pump goes out, at least on the E55, the car will still build revs and increase speed, but its like you're in one of those commercials dragging a 10' anchor or a piano. Parts of his problem sound like the IC pump, but I would think that this was something different.
Old Aug 28, 2007 | 12:48 PM
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
it's also hot and humid as hell around most of the us right now.
Old Aug 28, 2007 | 02:27 PM
pointman's Avatar
Thanks guys. I think you got the diagnosis right. Will report back when I know more.
Old Sep 8, 2007 | 01:43 PM
pointman's Avatar
Just wanted to say thanks. You guys were dead on.. ic pump. Replaced, and now the car is back to its old self! Thanks again.
