Part Number please... Valve Cover?
Old Aug 19, 2007 | 03:25 AM
Sidez's Avatar
Crossfire SRT-6
Hello I am looking for the part number of the Valve Cover... I think it is called.. It is the 2 covers located between the Air filter covers and the supercharger is between them.. The parts that say AMG in big Letters on them..
The left one has 4 bolts and right one has 3.. well you should know what I am talking about... if anyone knows.. please tell me the part numbers of both of these parts.. thank you very much
Here is a picture to refresh your memory
Old Aug 19, 2007 | 03:43 AM
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
You are talking about the surge tanks. I have no idea on the part numbers right now.
Old Aug 19, 2007 | 08:19 PM
boohooramblers's Avatar
Not an AMG :(
Originally Posted by Sidez
......It is the 2 covers located between the Air filter covers and the supercharger is between them.. The parts that say AMG in big Letters on them.....
Code3 is right - they are the surge tanks / top charge air distributors.
Both of them have 6 bolts - 4 on the medial side and 2 on the lateral side. The medial bolt nearest the firewall on the driver side tank is slightly obscured in photos.
...please tell me the part numbers of both of these parts.. thank you very much
Since I just took mine off - here's the part numbers:
Passenger side: A112-098-02-07
Driver side: A112-098-01-07
Those part numbers may not be exactly what is on the SLK32 though.....
Old Aug 19, 2007 | 08:34 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Passenger side: A112-098-02-07 Driver side: A112-098-01-07
Have you been fitting some upgrades perhaps?!
Sidez-
It’s not surprising that DaimlerChryslerAG cast nondescript parts for the SRT-6. Now that the divorce has been formally completed, and because you didn’t rat me out when I PM’d you with the front cover plate (112 010 05 67) information, trust the following will be okay with the AMG faithful;
112 098 01 07 (LH) & 112 098 02 07 (RH) are indeed the correct numbers for the "charging air lines" you seek. They are available only as a complete upper and lower assembly. Street price is ~$150 each. The (2) required gaskets are 112 098 02 80. If your parts man is from the fatherland they translate; “stuck dichtung.” You may want to consider replacing the (2) 112 094 22 82 surge tanks to Y pipe tubes and installing phenolic heat-attenuating spacers while you’re completing the swap.
Old Aug 19, 2007 | 09:05 PM
Not an AMG :(
Lol! Not yet! I had a nightmare last night - there was green film caked on to my intake runners / inlets. I woke up in a sweat and had to look..... All good - whew!!
Old Aug 20, 2007 | 03:48 AM
Sidez's Avatar
Crossfire SRT-6
Thank you very much for the information you fellas always come through
why purchase new gaskets? would the old gaskets be unusable? also how hard is the install..?
the y pipe tubes are for increased air flow?
Old Aug 20, 2007 | 10:13 AM
Not an AMG :(
My gaskets didn’t look reusable so I'm glad I had new gaskets lying around. It was a tad bit wasteful since I was just looking down there. But.... I wouldn't take a chance reinstalling the old gaskets - you definitely don't want any chance of an intake leak.
Re: the install, it's very easy - an hour max. For me, the only tricky part was releasing the bottom clip on the intake line/y assembly. Here's a good thread on the install......
https://mbworld.org/forums/showthrea...light=phenolic
Old Aug 21, 2007 | 04:55 AM
Sidez's Avatar
Crossfire SRT-6
Noob question my appologies but searching through the part number for the gaskets nothing has come up...
so I searched through keyword and is it a Pan Gasket, Manifold Gasket, Head Gasket, valve Cover Gasket, or an Oil pan gasket?
Thanks again
