Dyno results (large images attached)
Old Oct 22, 2002 | 03:32 PM
Jon Winter's Avatar
C32 AMG, CLK 320
Post Dyno results (large images attached)
Had my car dynoed after installing the ecu and pulley kit. Unfortunately I didn't get the before dyno for a comparison.
I am pleased with the seat of the pants results. Driveability is good, throttle response is quicker. Happy about no more top speed governor
Old Oct 22, 2002 | 07:13 PM
rrf's Avatar
rrf
3rd gear?
Jon, Thanks for sharing your data.
Apparently 3rd gear is the best gear to dyno in, smoothest and most indicative of power.
Your data looks like it correlates very well to another Renntech chart I saw (SLK32, but same motor and mods).
Was your car cool when tested? What was the weather like outside that day? Congrats!
Old Oct 22, 2002 | 07:26 PM
sticky2's Avatar
I'm a little dissapointed. 300 @ the wheels is 360 @ the crank. That is only 10 more hp more then stock is supposed to be. Does mercedes overrate the c32?
Old Oct 22, 2002 | 07:33 PM
Zeppelin's Avatar
C32
I hope your numbers are down due too the intercooler being heat soaked at those higher boost levels. It looks like something is wrong because the HP numbers begin tailing off after 4500rpm. My stock dyno chart shows a more straight line from bottom to top. If this is supposed to be true on yours it would produce another 20-30hp to the wheels.
My stock dyno is 294hp before the car was broken in. It is probably more now.
Old Oct 22, 2002 | 08:02 PM
sticky2's Avatar
A stock dyno of 294 is right where the car should be! That is good news. I wonder how much power you would make with a chip + pulley.
Old Oct 22, 2002 | 08:51 PM
Vadim @ evosport's Avatar
C32 AMG
Jon: It is always good idea to do a baseline. Of ten C32s that we ran stock, HP ranges from 270 to 297. So now there is no way to tell what the actual gain is.
Our C32 makes 297HP and 290 ft.lbs. of TQ with just pulleys and Stage I IC upgrade, on 91 octane. See R&D #4 post below. It desparately needs more timing to smooth the curves out. Also we always run cars through the gears, as it is more representative of street driving.
Old Oct 22, 2002 | 09:43 PM
Bux's Avatar
Bux
G
thats FU*KED up C32's from 270 to 297?!?!?! thats a pretty BIG diffrence!!!
what the hell can make such a diffrence? obviously at least 1 AMG worker there SUCKS and one knows whats up.
Old Oct 22, 2002 | 10:02 PM
amgme's Avatar
07 SL550; C32 (sold)
i know!! i wonder how there can be such a big difference. it's not like they're using different parts.
Old Oct 22, 2002 | 10:14 PM
Bux's Avatar
Bux
G
i wonder
who has a SLOW *** version of the C32? terrible..
Old Oct 22, 2002 | 10:37 PM
AMGDood's Avatar
C32 AMG
i got the slow *** version. My fastest quarter mile time is a 13.8
Old Oct 23, 2002 | 02:23 PM
Jon Winter's Avatar
C32 AMG, CLK 320
Question
I ran the 1/4 mile with the car in stock trim, except for wheels and tires.
ET 1/4 Mile 13.4833
Speed 105.8397
60 ft 5.7518
1/8 mile 11.3349
Capitol Raceway
Crofton, Maryland
2-24-02
