Here's what heat does to the brakes
Old Oct 23, 2002 | 01:43 PM
Jon Winter's Avatar
C32 AMG, CLK 320
Post Here's what heat does to the brakes
This shot was taken about a week ago. The calipers had already turned a light gold color from previous track sessions but now they turned this deeper gold color after my latest stint with the Ferrari club guys at Summit Point. Also notice the heat cracks in the rotors.
Old Oct 23, 2002 | 02:20 PM
anthem's Avatar
2007 S
Were those actually drilled by you or by another shop or are those actually drilled rotors by a manufacturer like brembo ? I'm curious as to if the heat actually caused the stress cracks on the rotors from already weakened/torqued areas on the rotor, or if that is what actually happens to drilled rotors.
I've seen drilled rotors that have been on tracks with heavy heavy use not exhibit the cracks that I've seen on those rotors. Something is awry, either whoever drilled those just drilled holes and torqued the area around the holes or those rotors are just not that good.
Old Oct 23, 2002 | 03:12 PM
Jon Winter's Avatar
C32 AMG, CLK 320
Question
Factory discs and pads after hard track use.
DL_AMG's Avatar
2011 C63, 2004 S500, 2013 E350, 2013 Ody Elite
Thumbs up Wow!!
I like the New color on your calipers but not the crack rotors. Well, it's time to get a set of new carbon rotor for your C32.
Old Oct 23, 2002 | 03:39 PM
JustinTRW's Avatar
C32 AMG
I have to ask, were you given a few cool down laps? If so, you should not be using the brakes at all during this time. Did your dealer ask when you went to get them replaced under warranty?
Old Oct 23, 2002 | 03:54 PM
Jon Winter's Avatar
C32 AMG, CLK 320
I do a slow cool down lap always. My Porsche Big Reds turned brown after some time. I did not ask the dealer to replace the calipers. Looking into a big brake kit.
Old Oct 23, 2002 | 04:03 PM
JustinTRW's Avatar
C32 AMG
I think they would, so you might as well do it. It's free.
Old Oct 23, 2002 | 07:15 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
hey, the new color of the Caliper is cool...just like those brembo on the new Z/G35 coupe. No, i'm not playing.
don't worry about the crack holes, they are bound to happen someday on the cross-drilled rotors. My bro has cross-drilled rotor from brembo for his car as well. it starts to crack after 30-40 k miles. Of course, tracking would make it appear faster due to the heat
Old Oct 23, 2002 | 07:22 PM
otoupalik's Avatar
MBWorld Founder
Jon,
WOW!
Yes, we have found that the breaks are great - for a while. The big brake kits are really nice.
The two that we are working on now are for both front and rear:
- Brembo 14" Front, 13.2 Rear
- MB SL55 Front and Rear.
That should make the car stop a bit better and allow you more longevity with rotors and caliper color! 8^)
Brad
