e55 rims on c32 ?
Old Sep 8, 2007 | 07:15 PM
Eurowow's Avatar
Amg C32
e55 rims on c32 ?
alrite folks, i tried & search the site but nothing really answers my questions>?!
I'm plannin on buying a set of E55 twin spoke wheels OEM 18 by 8.5 all four are the E55 front wheels. my qs is, will the set up bolt right on to my C32 ?
Any feeback greatly appreciated !!!
Old Sep 8, 2007 | 07:28 PM
jgsx's Avatar
04 C32
Wrong offset.
Old Sep 8, 2007 | 07:29 PM
Eurowow's Avatar
Amg C32
damm
Originally Posted by jgsx
Wrong offset.
Crossing my finger !!!! DAMMMMMMMMMMM it ! that sucks.
Old Sep 8, 2007 | 08:06 PM
Harry Madan's Avatar
03' E39 M5, 10' CLS63 AMG
the bolts on the E are thicker, but u can use the C bolts, but then the wheel will not sit properly, u will have problems. they are not a direct bold on.
Old Sep 8, 2007 | 08:14 PM
Eurowow's Avatar
Amg C32
hum
another word, it wont fit !?! i just dont want to use spacers or having issue with fenders 2.
Old Sep 9, 2007 | 02:27 AM
1Lop2K5C's Avatar
C63
An E63 wheels will bolt right on, just need different tire sizes.
Old Sep 9, 2007 | 02:40 AM
raymond g-'s Avatar
99 E320
i thought the split spoked E55 AMG rims were ET31 for the 8.5" width. is that
not similar to that which is needed for the C32? if so, I'm thinking you have a
chance at these rims fitting, provided you select proper tires. secondly, if your
bolts are 12mm x 12mm radius ball seat, note that these E55 rims utilizes 14mm
x 14mm radius seats. RAD hybrid bolts sold by otisincla.com are made in 12mm
diameter x 14mm ball seat x various lengths. the cross section of the E55 rim
is .75" (based of ball seat...to hub surface).
Old Sep 9, 2007 | 04:19 PM
Eurowow's Avatar
Amg C32
humm.
thanks for the link raymond !
Old Sep 9, 2007 | 05:27 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
they should work. Those type-IV split spoke should have the offset of 18x8.5 ET30-31 and 18x9.5 ET33. It comes on some SL500 sport and the E55. all you need is get the 12mm bolts
Old Sep 9, 2007 | 06:20 PM
raymond g-'s Avatar
99 E320
no, the rear wheel offset for the 9.5 width is going to be more like 38-39
Old Sep 9, 2007 | 07:31 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the SL500 sport split spoke wheels are ET33 for 18x9.5. they even fit on the W202.
Old Sep 9, 2007 | 07:33 PM
raymond g-'s Avatar
99 E320
ah, understood. you're talking about the SL rims and I thought we were
talking about the E55 rims he posted above. just dbl check before you buy.
Old Sep 9, 2007 | 09:07 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yea, meant to say the front one's the same, but the rear SL500 wheels will work.
Old Sep 9, 2007 | 09:14 PM
Eurowow's Avatar
Amg C32
humm
ok guys, the complete set of wheels are from E55 FRONT's ONLY ! which means all four wheels are E55 front wheels. Frank W, so all i need is 12mm bolts and it should clear with no problem? if so, i'm going to order a set of 12mm bolts. THanks for all the advise and helps ! I hope these works.
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
i thought oem w211 e55 wheels were 18x8 30et and 18x9 40 et.
Old Sep 9, 2007 | 09:16 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yes sir. just be sure you double check the offset.
what tire you going to run on 8.5 all around?
Old Sep 9, 2007 | 09:52 PM
Eurowow's Avatar
Amg C32
245 all around.
245 all around. Do i need any spacers ? all i need is 12mm bolts ? wow !!! now things are looking up a bit. THanks F W !
Old Sep 9, 2007 | 10:00 PM
rlee02135's Avatar
2004 C32 ///AMG
i doubt you'll get 245s to fit in front. it might work with a spacer if you are not lowered, but it'll be sticking out of the fender.
Old Sep 9, 2007 | 10:02 PM
Eurowow's Avatar
Amg C32
i'm running on 225 in the front right now... hahahah but since i'm not lower i think it should be fine ? !? what do you mean by running a spacer in the front ? wont that bring the width& stick out even more ??
Old Sep 9, 2007 | 10:07 PM
raymond g-'s Avatar
99 E320
- not just any 12mm diam bolts, but they *must* have 14mm ball seat,
otheriwise you lost contact surface as shown here
- the length of the bolt must pass through the rim, and extend the same
length as your current bolts through the rims you're using now. any
shorter and you may compromise fastening abilities. any longer and
you risk damaging the brake as the excess length protrudes deeper
into the hub and braking mechanism
Old Sep 9, 2007 | 10:47 PM
Eurowow's Avatar
Amg C32
thanks
thanks, i'll call the website customers service to double check.
Old Sep 21, 2007 | 10:50 PM
Eurowow's Avatar
Amg C32
ok
Help folks!!! got the 12mm 1.5 with 14mm ball seat, but the E55 8.5 wheels won't clear my c32's BBK...... i'm stuck.... when i install the front wheel it hit my BBK. My qs is do i need 5mm spacers ? C32 offset is 37st 32 rear ???
Twin split spoke E55 wheels is 35st. I'm lost... can't find the answer to my thread.
Old Apr 15, 2008 | 05:07 PM
spr's Avatar
spr
you need to run closer to 30 offset for 8.5 fronts- Get a 5mm spacer-
Old Apr 15, 2008 | 10:31 PM
1qikctr's Avatar
Merc power
dito
dito on the info.
Old Apr 16, 2008 | 01:02 AM
crazeazn's Avatar
C55
bah what a headache, hope u figure out evertyhing!
