C55 Dyno: What's the Stock HP/TQ?
Old Sep 25, 2007 | 10:47 AM
Drop-a-Daimler's Avatar
2006 C55 AMG, 2.8L Quattro, Softail Nostalgia 1550 (Stage III), Sporster (slammed)
I saw a dyno chart of a stock C55 and I think it said 327 HP @ 5700 and 341 TQ @ 4200 at the RW. With 16% drivetrain loss that would be 380 HP and 395 TQ. But MB says 362 HP @ 5,700 and 376 TQ @ 4,000 rpm. Anyone know what they usually make stock at the RWs?
Old Sep 25, 2007 | 11:03 AM
Quicktwinturbo's Avatar
CLS, SLK, ETC
I dyno'd at 301rwhp.. Didn't get my tq reading..
Those number seems lil high to me..
Old Sep 25, 2007 | 12:53 PM
Originally Posted by Quicktwinturbo
I dyno'd at 301rwhp...Those number seems lil high to me..
Yeah. And I saw your dyno sheet up on Drag Times. Pretty impressive too. Most there were coming in right around 300 RW hp. With 19% or 20% frictional loss you would be right at the factory numbers. I thought 310 might be typical RW. And dyno results can vary widely but not usually by 20 or 25 hp.
Old Sep 25, 2007 | 03:16 PM
1Lop2K5C's Avatar
C63
Here is a Dyno plot I found from RRI
http://www.rri.se/popup/performanceg...p?ChartsID=234
Old Sep 25, 2007 | 04:39 PM
Thanks! This is stock?!? I'm not sure I fully understand what they are reporting.
Powertrain performance
Wheel power 325 bhp @ 5530
Wheel torque 335 lb-ft @ 2996
Stated engine performance
Engine power 362 bhp @ 5750
Engine torque 376 lb-ft @ 4000
I read that as 325 RW HP and 335 RW TQ (they call it wheel power). With 17% power-tain loss that would be 380 HP and 391 TQ at the crank. What confuses me is their use of "bhp" when showing what they imply is wheel power. I thought "bhp" meant base horsepower or crank horsepower.
Old Sep 25, 2007 | 04:47 PM
CLS, SLK, ETC
different dyno.. that's prolly why.. I did mine on Dyno jet
Old Sep 25, 2007 | 04:49 PM
Vadim @ FD's Avatar
S600TT, R350
Early 55s are in 290s, later ones are at 300-305RWHP range.
If we use 17% loss, we got 300/0.83 = 361 HP.
Old Sep 25, 2007 | 05:35 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Depends on what kind of dyno though.
Old Sep 25, 2007 | 05:53 PM
Originally Posted by Vadim@GMGRacing
Early 55s are in 290s, later ones are at 300-305RWHP range...If we use 17% loss, we got 300/0.83 = 361 HP.
Ok, there we go. We should expect about 300 RW HP on the later models. Thanks.
Old Sep 25, 2007 | 06:33 PM
rory breaker's Avatar
Yes
Whats the difference between the earlier/later models that would result in the difference?
Old Sep 25, 2007 | 06:48 PM
1Lop2K5C's Avatar
C63
Earlier model meaning the 210 E55? or CLK55? Here is an interesting dyno from an SLK55
http://www.rri.se/popup/performanceg...p?ChartsID=607
Old Sep 25, 2007 | 07:25 PM
RawAMGpower's Avatar
2006 BMW X5 4.8is and 2005 C55 AMG
All these dyno's are with the brake rotors and wheels remove. This doesn't show you real world rear wheel power.
Old Sep 25, 2007 | 07:30 PM
1FSTAMG's Avatar
C32 AMG - RIP :(
How does one go about getting "wheel" horsepower readings if the wheels are removed?
It specifically says wheel power and wheel torque.
Old Sep 25, 2007 | 07:41 PM
1Lop2K5C's Avatar
C63
Well if you look at the "Details" tab, it mentioned what wheel/tire dimension was.
Old Sep 25, 2007 | 08:44 PM
Vadim @ FD's Avatar
S600TT, R350
Here are dynoes of stock W210 E55 vs. W203 C55. The difference is 1 point in compression.
Old Sep 26, 2007 | 12:06 AM
tripower's Avatar
Cars
bhp = brake horse power
There can be big swings on readings depending on the brand dyno a car is run on. There are also weighting factors that can be applied to adjust readings. From what I understand, Dynojet units tend to come in on the most realistic side of numbers.
Old Sep 26, 2007 | 05:06 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
I've heard from many quite the opposite. Mustang dyno's and Dyno-dynamics are said to give more tru to life readings. And usually lower #'s.
Old Sep 26, 2007 | 04:36 PM
tripower's Avatar
Cars
Interesting. I have a reading from a Dyno-Dynamics on my GTO and based on what others have run, the numbers seemed high. I found a local shop that has a Dyno Jet unit so I may put the car on there to compare the numbers.
Old Sep 26, 2007 | 05:35 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
I've dyno'd my car numerous times on different dynos and can tell you that Dyno-Dynamics yields higher numbers than Dyno-Jet.
Old Sep 26, 2007 | 05:50 PM
tripower's Avatar
Cars
That's what I've been told by many others as well. What was the approximate delta between the two different readings? I'm assuming of course you may have run the car in the same configuration on both dynos. Thanks.
Old Sep 26, 2007 | 10:05 PM
ProjectC55's Avatar
Not Adams dyno!
Old Sep 26, 2007 | 10:16 PM
Addicted2Speed's Avatar
Lotus Elise SLK55
My SLK55, which has the same engine, dyno'd just under 300whp. I would say that the norm is 290-310whp for these engines. There is no way that a stock C55 will dyno at 327whp, unless the dyno is not accurate.
