Got the car back. S/C replaced
Old Nov 27, 2007 | 06:08 PM
Chazz's Avatar
C32 ///AMG
Good grief. After having my car in the shop for nearly 3 weeks I Finlay got it back today.
I was having intermittent power loss with no rhyme or reason to it. Sometimes the car would run fine all day, sometimes I would barely get it out of the driveway and it would start. Sometimes it was 80+ degrees outside, other times it was in the 30's. There were a few other small problems I wanted to have looked at like the heated seats not working properly and a power drain on the battery.
I have an aftermarket warranty that after MUCH deliberation with the mechanic, Finlay agreed to cover it all. Well, almost all of it. I had to pay for a new EGR hose. It was cracked.
He replaced the super charger, seat control modules and both lower seat heaters. Which, by the way, don't feel right now because they aren't broken in yet.
So, I go and pick it up today. I drove it around town for about 20 min. then jumped on the freeway. Pulling onto the on-ramp, same problem. Power loss. ARrrgggg... frustrating. So, in a couple days I am going to take it back to the shop.
I know the IC pump has been a source of problems for many of us but he didn't think there was anything wrong with it. Please forgive me for my ignorance because I am NO mechanic, but if the IC pump is failing doesn't the car run hot? I keep a close eye on the temp but it never rises. The power cuts out even if the car is cold and it's only 30 degrees outside. So I know it's not a heat soak problem.
Anyhow, back to the shop it goes.
Old Nov 27, 2007 | 06:37 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Wow, they replaced the S/C when all it might be is a $350 I/C pump (possibly)? Consider yourself fortunate to have gotten a $7500 S/C replacement under warranty.
If the pump is going out, you will NOT see any rise in temps on your gauges. What is getting hotter is the IAT, or the air at the intake to the S/C. Once the air temps reach a set temp, the S/C will shut off to protect the engine. When my pump went out, the only symptom was the lawn tractor-like performance (off and on). The first time I took the car in, I told them I thought it was the pump. They checked it and said no codes were thrown so the pump was fine. Wrong! A few days later, on an average 70 degree day, I was chugging up the hill to my home. I took it back and, lo-and-behold, the pump was dead. They replaced it and everything has been great since. Outside temps can be deceiving with this whole pump thing. It is more about the way you have been driving the car that day.
I'd bet that they will confirm a dying pump on your car. Your warranty company will have paid your dealer an arm and a leg for a new charger for no good reason and your dealer will be rubbing his hands together hoping for another mark to wheel up to the drive.
Old Nov 27, 2007 | 07:07 PM
Chazz's Avatar
C32 ///AMG
So, What is getting hotter is the IAT, or the air at the intake to the S/C.
But even thought it's cold outside and the car really hasn't even had a chance to warm up it could still shut down the supercharger? While everything is still cold? Then randomly start working again?
Old Nov 27, 2007 | 07:22 PM
ScottW911's Avatar
The random part is quite characteristic of the I/C pump failure. The fact that the car is not warm is curious. Am I correct in my understanding that it is doing this before the car warms up sometimes? If so, is this first drive of the day or after the car has been run and parked for a while?
Old Nov 27, 2007 | 11:35 PM
Eurocharged Rick's Avatar
SPONSOR
it is your I/C pump based on your description...most dealerships hire parts changers now, not true technicians with trouble-shooting abilities...
i can send you a new pump and i bet your S/C never shuts down again...
Old Nov 28, 2007 | 12:21 AM
Chazz's Avatar
C32 ///AMG
It's going to be a few days before I can get it back into the shop. I'll pay closer attention to if it shuts down right after the first/cold start of the day or if it has a chance to warm up a bit before it does it.
Old Nov 28, 2007 | 11:53 AM
spr's Avatar
spr
sounds like you might as well upgrade to that lightening or johnson pump or whatever the best is just because eh?
Old Nov 28, 2007 | 01:02 PM
Fifth Ring's Avatar
C32 AMG
I'd agree if it was not under warranty. Even if the end result is superior, I would not be shocked to see Benz void the warranty.
QUESTION FOR CHAZZ: When they replaced your seat bottoms, did they use a leather that matches the leather you have? I had the same replacement and the leather seat bottom is a "flat" texture while the original seat is shinier.
Old Nov 28, 2007 | 02:33 PM
spr's Avatar
spr
Although the Q was not directed to me, I just had my drivers seat bottom replaced also. I can't tell a difference on mine other than the leather is super soft in comparison to all of the older leather. I'll have to look at the texture and shine since you mentioned it.
Old Nov 28, 2007 | 02:34 PM
spr's Avatar
spr
Good point on the pump also concerning the warranty. Too bad you can't have benz give you a $$ credit so you could get that pump, or try to work out a deal just to buy it and have them replace it with that unit under warranty somehow-
Old Nov 28, 2007 | 02:55 PM
Fifth Ring's Avatar
C32 AMG
I want to hear Chazz's answer b/c he's got a 2002 like me. It's possible (likely) that the leather texture changed in later years and they gave me the newer leather that is a mismatch.
Old Nov 28, 2007 | 02:58 PM
DarkXerox's Avatar
07 E550, 02 C32, 91 300E
Yeah my butt heater stopped working this year too. I'll probably have it replaced this summer when I have time (gonna get good use out of the extended warranty). But I want to know also if they use a different type of leather. Maybe it is just because the new leather hasn't been "butt-worn" like the old one?
Old Nov 28, 2007 | 03:42 PM
Fifth Ring's Avatar
C32 AMG
Nope. The leather throughout the car has a mild shine, like a nice, italian shoe. The replacement seat bottom has a completely flat texture. It's not "bad" it just doesn't match.
Old Nov 28, 2007 | 05:41 PM
Chazz's Avatar
C32 ///AMG
I hadn't really noticed until you said it but yes, the new bottoms are a flat black. They don't really match the mild shine of the rest of the car. Maybe they just need some conditioner?
The other thing is that the leather on the drivers seat is a bit more textured than the passenger seat. It has a little more grain to it. The passenger seat is butter smooth. Oh well. Luck of the draw when It comes to leather I guess.
