Ever tried this C32/SLK32 owners?
Old Nov 30, 2007 | 10:28 PM
c32used's Avatar
LET C32 2002
Question Ever tried this C32/SLK32 owners?
Any member use or have used this LSD on their C32 or SLK32. The company is named phantom grip. www.phantomgrip.com
Old Nov 30, 2007 | 10:45 PM
boohooramblers's Avatar
Not an AMG :(
Don't know if there are any documented cases of '32 owners having it, but I think some of the SRT-6 guys have.
Old Nov 30, 2007 | 10:56 PM
c32used's Avatar
LET C32 2002
Red face
Funny cause I got the info from there I should also post it there
Old Dec 1, 2007 | 05:43 PM
430's Avatar
430
SLK32
SteveL has one in his SLK32. It was recently installed and he does not have his car back but the feedback from the shop is all positive.
Old Dec 2, 2007 | 12:01 PM
Zeppelin's Avatar
C32
Us Honda guys won't even use that POS. If you really want an LSD then the Quaife is the only way to go.
Old Dec 2, 2007 | 01:26 PM
c32used's Avatar
LET C32 2002
Please say why you wouldn't use them?
Old Dec 2, 2007 | 01:28 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
FWIW, their "testimonial" page has quite a few good reviews from "honda guys," even compared against a mujen LSD (presumably, similiar approach as Quaife LSD)... have to take those with a grain of salt, though; who knows if they're true or not.
c32used's Avatar
LET C32 2002
People who use Quaife please chime in especially is you knew about this particular LSD...(JGSX) I value your opinion so please chime in.
Old Dec 2, 2007 | 01:59 PM
c32used's Avatar
LET C32 2002
Thats why I ask cause the website makes it look good but really need to know based of real reviews from members if possible.
Old Dec 2, 2007 | 03:12 PM
jgsx's Avatar
04 C32
Yup, I remember these from the Honda boys. They're good for drag racers on a low budget. The Phantom Grip is an OK option to improve traction. The Phantom Grip is the same type (if not the identical) of "LSD" modification that Kleeman sells. I think the E55 guys used to use those until Quaife finally produced a unit for our cars. Since the install is a significant portion of the cost, I'd skip the phantom and go with the Quaife. The Quaife is the best unit available.
Old Dec 3, 2007 | 12:10 AM
SteveL's Avatar
C43, SLK32, CLK63 Black Series
If Quaife is an option for you, it is a superior but considerable more expensive option. If you have a C32 and a 210mm ring gear then the Quaife will work for you. However, for an SLK32 and likely the Crossfire, Phantom Grip is the only way to go. The SLK32 has a 198mm ring gear and Quaife does not have a unit that will work. Trying to get a Quaife to work on an SLK32 would be a $3K to $5K effort at least.
Old Dec 3, 2007 | 12:33 AM
c32used's Avatar
LET C32 2002
Question
By any chance do you know the ring gear for the C32...SteveL says the ring gear for the SLK32 is 198
Old Dec 3, 2007 | 05:38 PM
SteveL's Avatar
Do a search for Quaife and you'll find some information. At least some C32 definitely have 210mm diffs. You might want to call your dealer with your VIN and ask them the size of your ring gear. An LSD is probably one of the best changes you can do on the car.
Old Dec 4, 2007 | 02:37 PM
m3_eater's Avatar
The Quaife was hands-down the best mod I ever did to the C32. In fact, I'd venture that it was the best mod I've ever done to any car I have ever modded period, because it was more valuable to the driving experience than go-fast mods like pulleys/software. The Phantom variety is not a true LSD anyway, since it has limited redistribution capability (60% locking, I think).
Old Dec 4, 2007 | 06:23 PM
c32used's Avatar
LET C32 2002
I am months away from even thinking of buying one......here's a perspective to think about.....I am not thinking of getting one for anything other then to see if performance on a dragstrip enhances mostly and very limited time at a auto x so based on that give me opinions...I may only own my car for a year two tops prior to upgrading and as a daily driver I am pretty laid back....my car sees more action at the strip.
Old Dec 5, 2007 | 10:28 AM
Zeppelin's Avatar
C32
I would not waste the money on an LSD if you are only going to have the car for a year or two. You will not see much if any difference on a dragstrip unless you have tons of mods and are seeing wheelspin over 40mph.
If you autocross all the time then maybe it would be worth it.
Spend the money on racing tires if you do not have them now.
Old Dec 5, 2007 | 10:31 AM
c32used's Avatar
LET C32 2002
Thats what great about inquiring first cause I need all kinds of responses especially negative ones. I am more against it then for it so keep it coming.
Old Dec 5, 2007 | 06:16 PM
OZAMG's Avatar
2002 C32 Stock at the moment
HI c32used, an LSD is a must for drag racing it will effectively double your traction. Our ESP simulates an LSD but only 1 wheel spinns at any one time the ESP then nips the brake on that wheel to move drive to the other wheel. I would expect to a lower ET with simmilat trap speed. Another trick drag racers use is to lower your rear tire pressure I would start at 25-30psi you want it as low as it will go withoiut spinning the tire on the rim. cheers Warren
