another issue
Old Dec 14, 2007 | 03:29 PM
john89011's Avatar
MB C32 AMG
another issue
I was at a light and my check engine light came on... when I started moving car almost felt like it was in limp mode and running rough. I pulled over to the side turned off the car and turning back on. Check engine light was still on but the car went back to normal. Next day I started the car and check engine light was gone. I drove for 300-400 miles and exact same thing happend. Any ideas? Yes I already replaced the IC and Secondary air pump. I did not have time to hook it up to a scanner to see what code it spits out Any one with similar issues?
Old Dec 14, 2007 | 05:02 PM
Eurocharged Rick's Avatar
SPONSOR
John,
even if the check engine light is off, the car still has a habit of storing codes, i would check to see if it still has a code stored, we could be of better help at that point...could be any number of issues...
Old Dec 14, 2007 | 06:00 PM
john89011's Avatar
MB C32 AMG
Thanks 1FASTC32! I also think it's time for a tune up
Old Dec 14, 2007 | 06:03 PM
SPONSOR
no problem, let me know if you need any parts for your tune-up...
Old Dec 15, 2007 | 05:09 PM
john89011's Avatar
MB C32 AMG
Eric, I plan on changing the wires and plugs anyways... do you recommend going with aftermarket or stick with OEM? I've seen many threads saying to go with aftermarket and others with OEM
Old Dec 15, 2007 | 05:25 PM
SPONSOR
the new LETMotorsports wires are the best of both worlds, OEM fitment and quality with better spark delivery...if you are going to run a bigger pulley then i would go ahead and go the one step colder on the plugs with a set of NGK's...
let me know if you have any other questions...thanks!
Old Dec 18, 2007 | 06:30 PM
john89011's Avatar
MB C32 AMG
Hey Eric,
I ran the diognostic and I get missfire on cylinder 4 and 6. So it's time to do a tune up. I will go with NGKs... which ones should I go with? Also what about wires? I will pick them up tomorrow. Also how to go about replacing them. I appreciate all your input!
Old Dec 18, 2007 | 08:45 PM
SPONSOR
Hey Eric,
John, go with the ones that i have on the website in the C32 section...it you are stock, go with the stock heat range, if you are modded, go with one heat range colder...
i would recommend the LETMotorsports Wires, but if you are going to get anything else, just go back with OEM wires...
let me know if i can be of further assistance...
Old Dec 19, 2007 | 08:11 AM
john89011's Avatar
MB C32 AMG
I'll place an order right after Christmas day.... I'll go with the LET wires and colder plugs that you have on your site. Thanks for your help Eric!
