Leaking Transmission
I was wondering if this is actually a common problem and if any one has had experience with this problem before. I've done a lot of research on this forum and I never came up on that problem with these cars. Luckily for me I still have warranty on the car, but this is one of numerous problems that I have to have fixed. I can't believe how many small problems I've had with the car, it's just become a real pain. On another note, I do love the car.
I assume they filled the tranny back up with fluid, it shifts like butter now...
i havent gotten it done yet... but i told them when they do it, to let a lot of fluid out so they can top off with a lot of new fluid haha
did you get them to fix the suspension component that was not attached?
i took my car to the dealer for this problem at around. 4000 miles.
they aloso metioned it was a common problem for the leak it was an overring seal that tends to go for some what reason, but i was told if it happens again they would go in more further.
All I hear from these people is bs. I guess now that they've been paid, they can take their sweet time. I tried to give them a call and they don't answer. I went to the shop and asked the people there if they knew any thing about my car and they were like you need to call the owner. He's away and when you call it should go directly to his cell, but he's not answering. Oh and I don't get a loaner either. I think this is the last time I deal with these people. They've been highly unprofessional and they just give me the run around. I need to go over there and raise hell
Haven't driven my car for a better part of 3 weeks since getting it back from the SD Autoshow. Decided to take it on a Sunday drive to grab lunch only to find a good amount of ATF on my driveway and garage floor. Towing my car to the stealer tomorrow since it was a steady stream and not drips.
26,000 miles on the clock.
I had this same problem back in 2006 with only ~12K miles on the odometer. I was told by my service advisor that it's a common problem on the C55 vehicles. When I took the car into the dealer, everything was taken care of under warranty. My car had to stay at the dealer for 2 days: 1 day for the repair and test drive, then overnight to make sure the oil leak was completely fixed.
I'm sure everything will be back to normal soon. Warranty should be covering all repair costs and also car rental fees.
"What?"
I said never mind. Just fix the burning smell.
I got a 08 C300 loaner. Not a bad ride.
But it is no AMG.....
So I got the new command disk too.
Oh, and they adjusted the steering well because it was 1/2 of a degree off center.
But I noticed 13 additional miles on my odometer when I got back in it today.
Things that make you go hmmmmm. Especially when I pulled out of the service bay exit onto the road and saw to parallel black marks on the road about 50 feet long.
