View Poll Results: Original Valeo, updated Valeo or Behr radiators?
Original Valeo Radiator without problems.
18
43.90%
Original Valeo radiator with problems.
2
4.88%
Updated Valeo radiator.
8
19.51%
Replaced Valeo with Behr radiator
13
31.71%
Multiple Choice Poll. Voters: 41. You may not vote on this poll
Valeo radiator or Behr?
I want to see how many C32 mainly 2002 who still have the original Valeo radiator with no issues.
I also want to see who has the updated Valeo and the Behr.
I ask cause the Dealer told me it was a batch of original valeo radiators and not all...I have the Original Valeo with no issues yet. Knock on wood.
07 E550, 02 C32, 91 300E
I had a glycol test done and it came back below the lower limit of detection so I should be fine. I have the updated Valeo though.
jtm65 (10-31-2023)
1 Post
2003 C32 AMG, 2003 E39 M5
Can you explain what the tranny jerk was. I just have not taken the time to research. What I have to do is do some research here and find out the main things that go on the C32 and see if I can get those addressed before the extended MB warranty runs out.
Erick I owned my C32 for 1 1/2 years and been fortunate. I don't know if radiator is indeed original cause I bought it used with 42k miles. If it hasn't broken in all this time adding 20k miles why should I worry? And I don't remember how Jerry checked my date on my Valeo radiator so can you or Jerry put how to here please so others can check.
I am not doubting you I just don't want to replace it if it was replaced prior to my ownership. I was warned by Jerry about mine being original but MB told me it was a batch that was effected thats why I put up a poll.
As I remember seeing Jerry check mine...if you look on passenger side of engine bay on top of radiator it will have a sticker showing date manufactured..now its not easy to get to and light helps alot. If I am wrong please someone chime in.
C32 AMG
Yes that's right. And even though yours has not failed. It's a $300 preventative fix vs a $3,000 transmission job. Not to mention - all radiators need to be replaced eventually.
If you have a Behr radiator, you will eventually die.
Or a Valeo, or even if you don't own a car at all.
More to your point, obviously all things will fail eventually. Do you have basis to believe that all Valeos (older and newer) will fail prematurely?
Dealer replaced a few things for me too...but I am feeling it again slightly now but very hard to notice now...maybe this cold weather.
1 Post
Is there a list that states manf dates for the bad ones? Like if it is before ?/?/2???? then you do not have the updated Valeo. Or if it is ?/?/2??? or after you have the updated Valeo.
Its after a certain date and AMG-Jerry told me so try to PM him or maybe 1fastc32 or other veteran knows.
silver 2002 c32 amg
I had a new Valeo fitted last year after my original one failed
I was worried that this may also fail at some point in the future but was told that the original design had been changed 5 times from the start of production, the last change taking place in 07
so any faults should have been sorted
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
i think all the info you need is on the site just do a search. production # for the rads etc.
i have a 9/01 build date so i did mine as soon as i found out about the issue. it's a no brainer guys the $300 is insurance against $3000++++.
Super Moderator
Swapped out the old Valeo for a Behr. Caught it just in time, as a glycol contamination test revealed trace amounts.
I had seen a Behr sticker underneath and thought everything was copasetic. Turned out to be on the heat exchanger…as verified during the LET upgrade. Oops!
A DIY link.
A DIY link.
A DIY link.
A DIY link.
glad that you caught it in time!
you had me worried for a little while...
Super Moderator
*off topic*
Thanks, Erick.
Since the transmission is okay, there’s enough in the budget for a LET pulley.
We’ll catch up soon.
Thanks, Erick.
