Any TRUTH to these "Myths"?
I've also heard that comfort mode is suppose to save gas even if you are driving relatively passive, however after been driving manual cars before the c55 I always was under the impression that starting in second gear uses more gas than starting in first?
Sorry if this is a repeat post but I've searched these topics but there hasn't really been any conclusive answer. Thanks.
Engines that produce high torque numbers low in the rev range may save gas starting in 2nd gear provided the vehicle is on flat terrain. If you were to drive in the city of SF, starting in 2nd gear would waste a lot of gas.
I always use comfort mode when I am with my family. The car runs good. When I am by myself, I switch to normal sometimes. The car is perfectly alright under the 2 modes.
without comparing torque curves, gear ratios & vehicle weight ... could 2nd gear start on a c230 work? ... possibly not?
If you had a car w/ a higher weight-to-power ratio & an automatic, second gear start may not work or make sense ... you might spend alot more time using the torque conveter before you finally got up to speed & locked up the clutches. (more fuel consumption & heat in the transmission/cooling system could result)
I'm pretty sure MBZ wouldn't knowingly risk higher warranty costs (especially for the engine & transmission-kinda pricey) to add a little known 2nd gear start feature on a "limited" production car.
This feature was NOT why I bought this car. Fuel economy isn't either. A performance sedan w/ less than 10lb/HP is why
My loaner c230 got nearly 10mpg better MPG's in mixed traffic ... I'm keeping the C55.
Still... car manufacturers have made bad decision before & will again, but this claim doesn't concern me.
...but I made a break through...I actually got 27mpg on the freeway cruising at 70mph...and then I stump on the gas and made it normal back to 22-23. LOL
With that said, unless the engine is ice-cold, you wouldn't be causing any damage or accelerated wear.
I thought all C230 were 4 cyl ... I should have said 4 cyl instead.
Again regardles of engine size, you still have to determine if there's enough tractive effort for a 2 gear start ... it still maybe possible w/ a 4 cyl, but probably alot easier & less stressful w/ a V8
But, all other years for this car start in 2nd gear. Unless you do the first gear trick every time you stop. I know my car weighs almost 4,000lbs and has ~150 hp. The 4cyl has only ~120hp and weighs just over 3,000lbs.
So the 4cyl has a 30lbs/hp ratio and starts in 2nd. I think your guy's cars are safe with about 14 yrs more of technology, more then twice the hp, and a warrenty lol.
You can check with MTI or kyniption to very that info. They probably know better then I.
