Maybe is a noob question...can c32 add blow off value(bov)?
Old Feb 25, 2008 | 01:02 AM
kjai's Avatar
integra
hi everyone I just search on youtube there is a c32 video with blow off value sound...just wondering can c32 add bov...as i know is for turbo car only...thankyou for answering...
the link is(the sound start at 2:00)...http://www.youtube.com/watch?v=ZhaHCNoN_9I
but i think is not a c32...only display to 260km...
Old Feb 25, 2008 | 01:18 AM
l3iGD's Avatar
AMG
How bout a LS1 swap??
Old Feb 25, 2008 | 03:59 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Nos!!
Old Feb 25, 2008 | 04:59 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
you answered your own question, with your question.
Old Feb 25, 2008 | 09:08 AM
crazeazn's Avatar
C55
while i do not know the intricacies of the c32, i know some aftermarket supercharged cars that have blow off valves.
Old Feb 25, 2008 | 09:09 AM
bumpnzx3's Avatar
W203 C230SS
Originally Posted by FrankW
Nos!!
you spelled it wrong. according to the pronunciation in The Gay and the Curious (Fast and Furious)- it's spelled Nawz
Old Feb 25, 2008 | 09:43 AM
Corrosive's Avatar
C32 AMG
I have never heard of a supercharged car ever having a BOV. Are you sure you didnt just hear the loud supercharger whine? There are fake BOV sound machines out there for posers... but I doubt a C32 owner would be so dumb as to do that.
Mind putting out a link of the video?
Old Feb 25, 2008 | 10:00 AM
MRAMG1's Avatar
S600, GL450, GLC 43
The better question is WHY
Blowers DO NOT NEED this valve, as the boost is directly porportinal to the blower size/rpm. Turbos use this to PREVENT overboost, this CAN'T happen on our cars since the blower is sized properly to limit the boost across the rpm range, ie constant boost pressure from 2000-6000. I guess if you were trying to be a poser you could add one to be a teenager again, but again, WHY
See yeah
Old Feb 25, 2008 | 10:01 AM
crazeazn's Avatar
C55
many of the lexus IS300 aftermarket supercharger applications had blow off valves (prolex, tbko, toyomoto, lms etc); i've yet to see a stock application that has it.
Old Feb 25, 2008 | 11:16 AM
red97z's Avatar
2008 E350 4matic
On my supercharged 97' LT4 camaro, I have a Bypass valve. It's made by vortech. However, my blower is a centrifugal unit, not a roots style one, or whatever you would call the one the c32 has..
Old Feb 25, 2008 | 11:50 AM
MRAMG1's Avatar
S600, GL450, GLC 43
A bypass valve, is just that, it diverts the boost when you close the throttle from 6000rpm away from the throttle body, and back to the compressor. A blow off valve, is set to prevent the boost from ever going past its pre-set value. Ie Indy cars are given a blow off valve when they compete from the officials so that they can't cheat, ie run more boost.
Also, keep in mind that centrifiguls build boost with RPM, the faster you spin them, the more boost you get. 2000 rpm =2 pounds, 3000 rpm= 4 pounds, etc, etc. Yes it does vary from blower to blower. This is just an example, so yours may be different.
Large blowers do have a blow off valve built into them, example a Weiand 6-71. This valve IS NOT for over boost, it is designed as a safety valve in the event of a back fire in the engine so that it does not damage the blower.
See yeah
Old Feb 25, 2008 | 12:12 PM
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
after a very heavy meal of black beans and rice i too, feel like i need a blow off valve.
Old Feb 25, 2008 | 12:15 PM
neihouma's Avatar
02 C32 AMG sold!
See yeah
Turbo application uses internal / external wastegates to prevent overboost.
Blow off valves (atmospherically dumped) / Bypass valves (rerouting back
to the source) recycles the kompressed air to the inlet of the charger
instead of outlet, which causes anti-surge ie: damaging the s/c or turbo.
Old Feb 25, 2008 | 12:58 PM
MRAMG1's Avatar
S600, GL450, GLC 43
+1
See yeah
But they do use blow off valves in racing on turbos to also prevent cheating, ie boosting past the regs
Old Feb 25, 2008 | 08:57 PM
1qikctr's Avatar
Merc power
* BINGO* another type of supercharger functions with a BOV is VORTEC system.
Old Feb 25, 2008 | 08:59 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
+1
See yeah
racing regulation FTL!
gives the team with more money and more engineering resource an advantage. therefore A1GP is most exciting to watch right now other than my favorite WRC. lol
Old Feb 25, 2008 | 09:43 PM
neihouma's Avatar
02 C32 AMG sold!
That sound was "added" into the video
This is a MORE realistic BOV on a C32 AMG (which I'm still trying to figure
out how he did it, yes he's a member here)
http://www.youtube.com/watch?v=ROtgZfeDZNs
Old Feb 25, 2008 | 10:15 PM
crazeazn's Avatar
C55
that looks lieka c55?
Old Feb 25, 2008 | 11:47 PM
JDC55's Avatar
+1
See yeah
Blow off valves are not use to regulate boost a wastegate is.
Old Feb 26, 2008 | 12:26 AM
crazeazn's Avatar
C55
BOV just releases excess throttle pressure? wastegate releases boost via wastegate spring or boost controller, anything more will not hold and it will dump
Old Feb 26, 2008 | 06:36 AM
MRAMG1's Avatar
S600, GL450, GLC 43
On a street car yes, and YES a wastegate is used to control boost. However CHAMP car racing uses a Blow off valve that is given to them PRIOR to the race by an official to prevent ANY team from trying to run MORE boost than the rules allow. So, the BLOW off valve , in this case DOES control/limit boost.
See yeah
Guys, I AGREE with you here, I am just stating one uniquie point of use, please don't beat me up on this. I helped out the Andreties in 92-95 at the Cleavland Grad Prix, NO I was NOT part of their team, I just met Michael at the Hotel and bought him some drinks, and he let me in his pits for a couple of years, LONG story.
Old Feb 26, 2008 | 10:17 PM
JDC55's Avatar
See yeah
Your thinking of a POP OFF VALVE not a Blow off Valve.A pop off valve opens when the set pressure is exceeded in the manifold. A blow off valve is a vacuum-actuated valve designed to release pressure in the intake system of a turbocharged or centrifugally supercharged car when the throttle is lifted or closed.
Old Feb 26, 2008 | 11:14 PM
cnchung's Avatar
C32
I think the sound was "added" too. The sound of a C32 does not sound like it is in the vid. The car did not accelerate the way it should after reving it for a few gears.
The vid you suggested sounds more like a BOV. Personally I don't know how a BOV should work properly with a supercharger. Isn't the SC clutch is already doing this job?
With a nice pulley, the car already sound awesome. What more do we need?
Old Feb 27, 2008 | 12:47 AM
crazeazn's Avatar
C55
for the second time isnt that C55?
edit: maybe a ricer?
Old Feb 27, 2008 | 06:50 AM
MRAMG1's Avatar
S600, GL450, GLC 43
OPPS, me bad, yes you are right my friend
Forgive me, I only have used and LOVE Positive displacement superchargers, ie BOTTOM END TORQUE.
SORRY
See yeah
