anyone know of a lightweight wheel?
Old Mar 30, 2008 | 12:22 AM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
I'm looking for a light weight wheel at a reasonable price I don't really want to brake the bank but Not sure if i want to dump 4k just on rims. And.. does anyone know how many pounds a stock 18 inch AMG wheel is?
Old Mar 30, 2008 | 12:27 AM
c32used's Avatar
LET C32 2002
I don't know the cost but I did hear they are much lighter then stock its the Renntech monolites(I think)
Old Mar 30, 2008 | 12:39 AM
Addicted2Speed's Avatar
Lotus Elise SLK55
The lightest are usually forged 1 piece wheels, but the most well known ones run at $1,200 or so per wheel. I would say look on ebay or the classified section of this site for good deal if you don't want to break the bank.
Old Mar 30, 2008 | 12:48 AM
rlee02135's Avatar
2004 C32 ///AMG
try HRE comps or iForged Track Edition
Old Mar 30, 2008 | 01:13 AM
hooleyboy's Avatar
C55,SL55,C63
should i lower my car if i go with a set of 19's do you think i should stay with 18's and maybe just widen up the rear to maybe a 9.5 or 10 inch wide wheel?
Old Mar 30, 2008 | 01:16 AM
andy_meng1024's Avatar
2003 SL55, 2010 C63
I like the 19" lowered 8.5 and 9.5 and it's the most common combo
Old Mar 30, 2008 | 01:18 AM
hooleyboy's Avatar
C55,SL55,C63
Ive never lowered a car before what should i do to lower it? or what would i need to get?
Old Mar 30, 2008 | 01:31 AM
2003 SL55, 2010 C63
Lowering springs or coilover kit. I'd go with coilover if I have a C55 tho.
Old Mar 30, 2008 | 12:11 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
+1
Another forum member and I met up to compare his stock ride height C55 and my C32 on H&R sport springs w/ #4 (17mm) rear spring pad... there really wasn't much difference at all, maybe half an inch or so. So I agree, with the C55, you might as well leave it stock or go with a full coilover set-up - KW (V1 or V2) and Bilstein PSS9 seem to be the favorites of C55 modders.
Old Mar 30, 2008 | 12:42 PM
crazeazn's Avatar
C55
theres some BBS LMs for sale by another member those should be lighter than stock
Old Mar 30, 2008 | 03:34 PM
SRT6's Avatar
srt 6 chrysler crossfire
Renntech
I might have some 19s Renntech Monolites for sale I am debating putting them on my crossfire or not. Two of the rims have tires that are in great condition. PM me if you want more details
Old Mar 31, 2008 | 12:20 AM
power-fade's Avatar
"One Man. One Engine."
stock 18s is about 30 lbs each
Old Mar 31, 2008 | 01:05 AM
hooleyboy's Avatar
C55,SL55,C63
so are forged wheels really worth the money? I mean you can get some good looking wheels from a reputable name that are not forged for much less. any suggestions on that? I wouldnt mind going with an 18 inch wheel I'd like to go 19x10 or 18x10 for the rear. But 19's with a good lowering kit look amazing. I'm just worried about going bigger and having my car feel slower with a bigger turning mass.
Old Mar 31, 2008 | 01:50 AM
calimax's Avatar
RENNtech C32 AMG
hey, with the power of an AMG vehicle, your not going to notice the difference. If you do, the look of a bad *** AMG, with a sweet set of rims, will greatly offset the difference!
Old Mar 31, 2008 | 12:48 PM
c3232c's Avatar
02 c32 99 superduty
I noticed a little power loss on mine with 19's, granted its not a c55. When I throw my 17's on for the winter I can feel an improvement on acceleration. Just have the 19's for every day pimpin and some lightweight wheels for the track. I am gonna go with the enkei's I had mentioned before. Now I am just trying to find a lighter tire, Nitto drag radials weigh in at 25.6 pounds each for a 16 inch tire, That seems a little high to me.
Old Mar 31, 2008 | 05:23 PM
moosejaw's Avatar
none
Try the OZ superlegerra
Old Mar 31, 2008 | 06:05 PM
c32AMG-DTM's Avatar
I thought the only one that fit our car was the 19" 3-pc., which is $1,000+ per wheel...?
Old Mar 31, 2008 | 07:11 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
to name a few off the top of my head and searched a bit for ones that i don't know the weight.
Forged wheels:
BBS RE 20.3-21.5lbs for 18x8 ET35 and 18x9 ET38 (i run 5mm front and 10mm rear BBS spacers make'em ET30 and ET28, but they are not needed to clear calipers)
BBS LM 23.5-23.9lbs for 18x8.5 ET30 and 18x9.5 ET32
BBS RS-GT 20.8-21lbs for 18x8 ET35 and 18x9.5 ET32.
BBS RG-R 20-21lbs 18x8 ET35 18x9 ET38. (12mm spacer from BBS is needed to clear the caliper.) look at BlakeP's car for example.
OZ Superleggera 3. 18x8 ET36 18x8.5 ET32. these should be around 21-22lbs.
RENNtech Monolite. 18". forgot the width or offset, but they should weight around only 18lbs.
SSR Comp-H 18lbs 18x8. most likely discontinued.
SSR GT3 18x8.5 18x9.5...not sure if you can even find these anymore either.
cast light weight wheels:
OZ ultraleggera 18.5lbs for the 18x8 ET35
OZ superturismo 24.7lbs for 18x8 ET35
OZ Crono 20lbs for 18x8 ET35
BBS CH 24.5lbs for 18x8.5 ET35 (need 5mm spacer to clear coilover)
BBS RX 24.3lbs for 18x8 ET32 (probably needs a 5mm or 10mm to clear the caliper. This is basically the cast version of the RG-R)
BBS RA approx. 22lbs each. 18x8.5 18x9.5 ET32. They are discontinued, but you can find them used usually on Audi forums. All you need is make the center bore bigger if the RA doesn't run BBS's hubring/spacer design.
other options I know less about which can be custom ordered in 18" spec you want if the shop has contact with Volks/Rays and Work:
Volks Racing TE37
Volks Racing CE28
Work Wheel VS-XX
hope this list will help some of you determining what you want for light weight wheels. There are more of them in 18" fitment such as the mentioned Enkei's etc. feel free to add them if you are sure about them.
Old Mar 31, 2008 | 07:35 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
to answer question on bigger wheel hurting performance. yes it does. larger which usually heavier wheel require more rotational force to get it going, so taking off from a stop will feel different. once on the move you don't feel as much difference. Bigger contact patch i.e. 245 vs 265 will mean better traction from a stop which can make you think you lost power because it doesn't chirp.
light weight wheel's advantage is that you have less unsprung weight at each corner which in terms makes the steering response better and handles better because there are less weight at each corner to swing into the corner. 18 vs 19 advantage is on the weight of the wheel, weight of the tires, and tire width. we all know bigger contact patch can mean better traction, but it also means more friction against the road. 18 vs 17 is more about tires. although low-profile some 17" tires can still have soft sidewalls which can retard the steering response. 18" gives you an option to upgrade to larger caliper and light weight 2 piece rotors as well which is another way to improve handling.
Old Mar 31, 2008 | 07:50 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
I put 18" ultraleggera's on my car...18lbs, can straight arm them...
Old Mar 31, 2008 | 11:44 PM
hooleyboy's Avatar
C55,SL55,C63
[/QUOTE]
this is the wheel look im looking for size wise i quess not so much the wheel but the way it fills the void and is flush with the car.
Old Apr 1, 2008 | 01:54 AM
DarkXerox's Avatar
07 E550, 02 C32, 91 300E
Yeah I looked into the volk wheels before and they only come in 18x8.0 with our bore/bolt pattern. Shame because they are by far the lightest out there.
Old Apr 1, 2008 | 03:20 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
When I upgraded to the 18" AMG rims, they weighted 34 lbs in the rear (but they were chromed) I never got a chance to weight the front ones
RennTech monolites are one of the lightest and high quality rims out there, but unfortunately they are outrageously expensive. I think the 19" monolites weight about 17 to 18 lbs.
Old Apr 3, 2008 | 01:03 AM
c32used's Avatar
LET C32 2002
HEY A MEMBER NAMED HANSElLEE JUST POSTED A THREAD FOR SALE OF RENNTECH MONOLITES $2000 SHIPPED ANYWHERE IN USA.
Old Apr 3, 2008 | 02:18 AM
calimax's Avatar
RENNtech C32 AMG
Originally Posted by c32used
Hey a member named HANSElLEE JUST POSTED A THREAD FOR SALE OF RENNTECH MONOLITES $200 SHIPPED ANYWHERE IN USA.
wow, you totally forgot to add an extra 0! oh well, made me look anyways, lol
