what is the widest tire you can fit on a stock C32 rear wheel?
Old Apr 25, 2008 | 07:30 PM
BARRATT's Avatar
2002 Blue C32
I would like to stick to same over all height....Just wider.
Hopefully by next week I will NEED the wider tire.
Old Apr 25, 2008 | 07:45 PM
bud4ya's Avatar
2003 C32 AMG, 2003 E39 M5
If you doa search you will find plenty on this subject. If I remember right I am thinking 265's maybe.
Old Apr 26, 2008 | 12:38 AM
timberman's Avatar
silver 2002 c32 amg
255's
Old Apr 26, 2008 | 01:13 AM
c32used's Avatar
LET C32 2002
Originally Posted by timberman
255's
+1
I have only read 255s and tire shops say likewise...
Old Apr 26, 2008 | 09:01 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Would agree on the 255's.....running them myself
Old Apr 26, 2008 | 09:12 AM
MRAMG1's Avatar
S600, GL450, GLC 43
On a 8.5" rear, 255 is the absolute widest you want to go. Check the tire specs and they tell you recomended rim widths.
See yeah
Oh yeah, I have bridgstone 050 PP's 255's on mine and LOVE THEM
Old Apr 26, 2008 | 10:15 AM
turbo16lbs's Avatar
1991 Toyota MR2, 2002 C32 AMG
Edit: I'm an idiot
Old Apr 26, 2008 | 01:23 PM
Chazz's Avatar
C32 ///AMG
Any problems with going to 255's on the rears with my car being lowered?
Old Apr 26, 2008 | 01:31 PM
c3232c's Avatar
02 c32 99 superduty
I think you would be ok. I am running 265/30/19 and I have one little spot that rubs so I think 255's should be ok.
Old Apr 26, 2008 | 02:26 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
265 with rounded side walls is the widest most go and 255 w/o rounded side walls.
Im pretty sure i read of someone on here who had 275s w/ drag radials.
Old Apr 26, 2008 | 05:23 PM
kindafast's Avatar
W210 E55 & W204 C63
Doesn't wider tire cause the tire to wear out faster? Also how does wider than recommended tire affect turning at high speeds?
Old Apr 26, 2008 | 08:34 PM
andy_meng1024's Avatar
2003 SL55, 2010 C63
I have 275/30/19 in the rear with 9.5x10 wheel and it's fine even after lowering springs. No rubbing at all with two people in the back. Haven't try three people in the back tho.
Old Apr 27, 2008 | 08:59 PM
bud4ya's Avatar
So if you stick with the stock rims looks to be 255's. I know you mentioned you wanted to maintian the same height. I am assuming you mean sidewall height? If that is the case the 255's on the stock rim are going to be a thicker sidewall than what you have now with the 245's. I was going to go 255's myself but decided after looking at the increase in the sidewall I decided to stay with 245's. Kind of wish now I went with the 255's as they do look wider.
Old Apr 28, 2008 | 01:48 AM
9krpm's Avatar
2004 C32
How does the car handle with wider tyres in the rear? Does it worsen the understeer?
How much wider can you go at the front?
