high flo cats
Old May 19, 2008 | 10:42 AM
amgstyle's Avatar
2002 SLK 32 AMG
high flo cats
hey guys i have a slk 32 and i just installed my eisenmann exhuast. now i want to put in high flo cats where the primary cats are, but don't know what size to order? wat's in inlet/outlet size?? also should i get 200 cel count or 300 cel count? and who makes good cats?? thanks guys
Old May 19, 2008 | 12:08 PM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
I know Kleemann makes 200 cel cats that replace the secondary cats. I'm not sure about the primary though....
Old May 19, 2008 | 12:53 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
I thought I'd read that the stock primary cats in the AMG exhaust ARE high-flow?
Old May 19, 2008 | 01:13 PM
MRAMG1's Avatar
S600, GL450, GLC 43
+1
Alot of money for little or no return.
See yeah
Old May 19, 2008 | 04:19 PM
alroumi's Avatar
G55, G500 & SLK55
The primary catalytics are heavy and are extremely restrictive, an identification to this is the restrictive headers and airbox setup by replacing the current headers and airsystem a 30hp gain is possible.
Old May 19, 2008 | 04:28 PM
MRAMG1's Avatar
S600, GL450, GLC 43
If you check out LET's and Vrus sites, they don't get 30 hp gain on a C32 my friend, even with headers. Maybe, and I do mean MAYBE, on a 55 series, but not out of our V-6 my friend. Thats way too optomistic, IMHO.
Weight wise you might shed 5-10 lbs, but come on not even Michael Schumacher would notice that difference.
See yeah
Old May 19, 2008 | 05:38 PM
alroumi's Avatar
G55, G500 & SLK55
See yeah
I was referring to the 55's.
Old May 19, 2008 | 06:37 PM
MarcusF's Avatar
2002 CLK430
Does a stock C32 runs 14 psi? If so, is that boost bled down at redline? If 14 psi is correct, and it isn't bled down at redline, then at 6000 RPM, a C32 ingests more air than a C55.
This would mean the exhaust flow requirements for a C32 are greater than a C55.
Old May 19, 2008 | 06:51 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
I believe Brabus makes some as well, but they're insanely expensive.
