just got back from a 900 mile roadtrip with the code 3 pullley and...
Wow pretty amazing what a question turns out....for sure C55asleep? in Florida is a pretty fast car so guys unless you can do 12.4 or better you are looking at a rude awakening....C55asleep? being that the C32 is forced induction a small 30-75hp bottle is actually recommended I was told that a 30hp bottle going thru the S/C will yield like if it were 75hp bottle...but as AMG-Jerry has pretty much everything you can imagine his car has major spin issue so I say before anyone embarasses themselves run your car an get used to it first...don't presume it will get up and go to the 12s easily launch and other attributes are eccential to get a car to lay the power properly to the ground...that being said be careful all![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
I am not sure how thick or what your guys' inter-cooler looks like but on Ford Lightning they are 5" deep and the intake temps only dropped something like 10 degrees if I recall correctly. Horsepower did not even match the shot size past 50-75hp(lower) but torque was still up there.
Is that system even hooked up to your car or just having fun with these guys? The bottle is not tight in the brackets and where is that line going as the motor is the other way? ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Looks to be just sat in there for a picture.
02 C32 AMG sold!
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#38
02 C32 AMG sold!
Kinda hard driving / spraying with a camera in hand, but I do have a boost
gauge nonetheless. The car runs 18.5psi w/out spray already. But when I
go to the dyno next time I'll get something to wet your pants I guess.
Yes he has internet police. He's been to the dynos & track meets I set up.
https://mbworld.org/forums/c32-amg-c55-amg-w203/223446-let-s-he-vs-code3-s-he-iat-dyno.html
https://mbworld.org/forums/c32-amg-c55-amg-w203/224886-18-5psi-40deg-f-20psi.html
https://mbworld.org/forums/c32-amg-c55-amg-w203/223444-dkflipse-s-c32-mustang-dyno-w-19-wheels-352rwhp-361rwtq.html
#39
1991 Toyota MR2, 2002 C32 AMG
https://mbworld.org/forums/showthread.php?t=223446
https://mbworld.org/forums/showthread.php?t=224886
https://mbworld.org/forums/showthread.php?t=223444
P.S. That second thread is a bit depressing.
#40
02 C32 AMG sold!
low 13's and if your on drag radials into the 12's.
