Misfire under load due to cracked Evo sport header
p.s.:the purpose of this post is just a reference for anyone who has got his CEL on but can't figure out the problem.
For that kind of coin, I would certainly want a new set.
See yeah
Ok I understand custom but do you remember what size and who made or sold it? I was leaning on trying the C3P S/C pulley with my 178 pulley but this scared me
luckily it was only the header that took the major damage but who knows maybe his wallet did too since he took it to several shop to diagnose the problem til it was found.
NOT that the CP + SC pulley combo somehow CAUSED the header crack, which seems to be how the rest of you are taking it...
EXAETLY!!
spr, hooleyboy and MRAMG1: it's too much hassle to ask them for a new set, so if it could be fixed, I'd just fix it right away.
Now a question???
Whose S/C pulley you have and what size crank pulley are you using? If you can please try to dyno it with combo pullies...
you hear a nasty exhaust leak?
Also having a crank pulley / supercharger pulley combo with no tune, CAN
cause the car to run lean, and WHEN you run lean the exhaust temperature
goes through the roof.
Are you planning to do a dyno? Because I think you're the first person who is using an sc pulley and a crank pulley in combination. A lot of people are interested in the result. Do you think you can do a review?
Which pulley did you have first? and how did it feel once you got a 2nd one? Do you get belt slip? Does you sc overheat? Have you done 1/4, dyno?
I am very interested in this if really little to none issues..do you have a tune?
I truely want to see a review if possible...how long you had it?
Anyway, I'm running ASP + Code3 and my car pulls very hard in the mid-range, but I lost A LOT of power above 5000 RPM.
Jerry @ LET has my ECU as we speak however, and I am confident this will fix the problem.
