carbon fiber Driveshaft
http://www.pstds.com/critical_link_drive_shafts.htm
http://www.stangpro.com/html/articles/driveshaft.htm
That's the kind of thing I like to see. Complete with before and after dyno. Surprisingly he did pick up some HP and Torque.
-Rich
stocker is steel, my "fear no beer" magnet sticks. usually aluminum shafts are a bit larger in diameter. the trans tunnel is tight, it might be a difficult fit.
Stock driveline, 420 bhp, driveline losses equivalent to 19%, 420 * .81 = 340 rwhp
Modified driveline, 420 bhp, driveline losses 25% better than stock (19% * .75 = 14.25%), 420 * .8575 = 360 rwhp
In conclusion, if you could cut driveline losses from 19% to 14.25%, you could gain 20 rwhp. Hope that helps
Were I'm at I'm just about out of bolt-on mods (that gain HP) that i can do other than a supercharger. It would be nice to cheat the system and steel back some of the power the car is taking away. i think I'm talking myself into my next mod. it if even can be done.
Think about it...if NASCAR still uses steel driveshafts than this is the best to use. The only other safe material for a driveshaft is aluminum.
A Carbon Fiber driveshaft may be ok for normal use on a small car like mine, but not on a high performance Benz...
If you don't believe me try it, I bet it won't last 6 months unless you drive around like a grandma.
I took a class at NASCAR Tech about drivelines and transmissions, and seen pictures and heard stories about the CF shafts.
Like I said before, Aluminum is what you want.
As an example you can look at flywheel based UPS systems. The flywheels, which are carbon fiber, will spin in excess of 20,000rpm's. I can assure you that is far faster than our little driveshaft will ever see. The primary reason that companies go with a carbon fiber flywheel on these UPS's is because of safety. If they explode it just turns into a fiber mess. And don't forget the reliability these things must have. I've seen them installed in hospitals before where power interruption is absolutely unacceptable. Life expectancy on them is 20+ years at that constant speed.
My main point on that was just that you shouldn't use NASCAR as a baseline for your decisions. If I'm not mistaken they're still using carb's instead of fuel injection.
I like to think of it this way... With insanely over priced mods for out cars Most other C/F drive-shafts cost around 1k. this seems like a good deal for what you get. I mean you get a lighter drive-line that takes less power to spin than a heavier one and its safer. if our drive shafts were ever to brake it would cause a catastrophic disaster to your car causing damage to many parts. As said before ^^^ If the C/F drive shaft was to fail it would just turn to "dust" causing much less damage to your car and to you. We all know the more something weighs the harder it is to move. I think it all kinda goes along with light weight pulleys and flywheels, maybe even wheels too. we all know the lighter the wheel is the easier it is for the car to move them. I would think with a lighter drive shaft less energy would be absorbed in trying to spin it. then that savings would be passed down though the drive system and onto the wheels... were it counts. Just my take on it I could be wrong IDK.
