Removing cats on C32
I know i wont pass smog without going to a "special" smog shop but how loud will the exhaust be if i just leave the resonator on but remove the cats?
Is your 02 under 80,000 miles if so just go to the dealer the failed one will be replaced for free.Any o2 sensor problems lately?
ohlord
you also need to make sure the debris from the cat did not foul the resonator or muffler.
If it was one of your secondaries that went bad, cut them out and don't look back; no annoying noise or CEL. If it was one of the front cats, I would have them replaced.
I think ill replace the primary, remove the secondary and the resonator for a better exhaust note. But will i still need a "special" smog to pass?
)My impression was entirely positive. The car felt very fast, and sounded really mean. At highway speeds, it maybe resonated a little into the cabin, but hardly noticeable. Under hard acceleration, the car sounds very unique and nasty.
My $.02: The C32 engineers designed the C32 motor to run with *** PSI of exhaust backpressure. They designed the cats, the resonator, and the muffler to maintain this amount of backpressure. On a stock C32, removing any of the exhaust components will probably have either no effect or a negative effect on engine power, as the backpressure will fall below what the C32 motor was designed for.
However, it seems to me a matter of logic that, if you have increased air/fuel consumption by increasing boost (i.e., pulley mod), you will also increase exhaust backpressure. In that case, the removal of some of the exhaust components, and consequent reduction in exhaust backpressure, will bring the C32 back to its optimal backpressure figure, and the result will be full enjoyment of the increased air/fuel consumption resulting from the pulley mod.
I think this makes sense?
-j0hn
So im thinking of just putting some high-flow cats from magnaflow as the primary and no secondary cats. Will i have any issues with the o2 sensors and high flow cats? I alrealy have a check engine light with the cats removed and the o2 sensors still in place.
Or should it be ok?
Or should it be ok?
Anyway, I tried replacing them with metal substrate cats but they did not last long. The metal substrate quickly failed (I believe due to extreme heat). The C32 is specifically designed to transfer as much heat to the cats as possible for quicker cat light off. That's why the front cats are mounted so close to the engine (Mercedes also used double walled manifolds and a single exhaust valve rather than two exhaust valves). I don't believe the metal substrate cats can handle this level of heat, as it is merely corrugated foil. I have purchased Magnaflow ceramic cats instead; I think they should be able to handle the heat.
If you still get a CEL after replacing with high flow cats... feast your eyes
:http://www.msprotege.com/forum/showt...hp?t=123634664
http://forum.e46fanatics.com/showthr...ht=o2+defouler
http://www.inlinefour.com/blcelelad.html
http://weapon-r.com/english/index.ph...oducts_id=6219
http://www.statracing.com/buy/blox-ce.asp
Vids plz.
The dealer and many exhaust shops are charging $1500 per side for replacement cats. If your going to replace the cats you have the buy the entire pipe with the 2 cats on each pipe. At $1500 retail my guess is wholesales is about $750, it isnt worth it to me to replace those cats if im going for performance mods.
Ill try the ceramic cats as advised.
This is without res cats on right? http://youtube.com/watch?v=qtHq3kSFpfY
