a few questions
This is just one post from Brandon suggesting plugs be re gapped when changing out to any pulley that increases boost. Did you read all the posts on the subject?
because I am pretty sure it was mentioned more than once. Maybe things changed since then I do not know. I did some homework before I throw out that comment on the plugs. If this has changed or you have other info that suggests you should not re gap I would be interested in seeing it If I am incorrect on this I apologize for any false info.
That first graph was actually the best looking run before we regapped the plugs down to 035. Some of the other runs we did before that, demonstrated just how important regapping the plugs is. So whether you are running a crank pulley, or the new sc pulley, regapping plugs is recommended. I was planning on doing a separate post with before and after dynos in regards to regapping the plugs. To be honest, I regapped in stages. First from 039 to 037, then from 037 to 035. After 035, everything always looked good. That first graph was an 037 run. The last was an 035 run. Every dyno at the stock gap, running the sc pulley, looked far worse. Power drop off was awful. Regapping the plugs will completely reshape the upper part of the power curve.
__________________
Brandon Smith
Owner, Code3 Performance
www.code3performance.com
brandon@code3performance.com
See yeah
See yeah
