dealer installing Behr or Valeo's??
Old Jul 17, 2008 | 02:51 AM
pointman's Avatar
a car that can't do the throttle reset.
I have an 04, if they put in a new radiator, is there anyway to tell if its a Behr or a Valeo? I looked for the Valeo sticker, but can't find it. THis is the most paranoid driven part of owning the 32 for me... worrying about the bad radiator.
If the dealer replaced it, are all replacements Behr now? Thanks.
Old Jul 17, 2008 | 11:11 AM
C32AMGSC's Avatar
03 C32 AMG
You will see the Valeo sticker on top of the radiator. You'll need a flashlight to see the numbers clearly.
Old Jul 17, 2008 | 12:25 PM
pointman's Avatar
There is a plastic piece installed above it, so I would have to remove it to see it?
Old Jul 17, 2008 | 01:01 PM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
I'm not a C32 owner, but I did some research on the car in this forum. Correct me if I'm wrong, but NOT ALL Valeos are bad. They redesigned and corrected their flaw over time.
I THINK a general rule one can go by is if your car has a build date after 09/03, your radiator should be ok. This was mentioned in a discussion in this forum. Once again, please correct me if I'm wrong, but I think this is correct info.
Old Jul 17, 2008 | 02:02 PM
DarkXerox's Avatar
07 E550, 02 C32, 91 300E
Just to be safe though, if you have a Valeo, it wouldn't hurt to have a glycol test done. Even though I have the "second version" of the Valeo, I still had it tested.
Old Jul 18, 2008 | 12:18 AM
pointman's Avatar
I have never read anything about Valeo's being updated, but you may be right. I have a mid 04 build so I should be ok off of the initial radiator. BUT it was recently changed by the dealer, and now I find myself worrying that my once safe car from the factory, is now not so safe.
Old Jul 18, 2008 | 03:20 AM
calimax's Avatar
RENNtech C32 AMG
Should be way updated by now. I just bought a new Valeo from the dealer, with the production date of something mid 07. I Replaced it due to damage, not for the "leak", and last month I performed the glycol test at the dealer with the original one, and it came back neg.
Old Jul 18, 2008 | 12:12 PM
razormb's Avatar
CLA
I got lucky when I bought my 2002, the history report from MB indicated that the radiator had been replaced at the 50K mark. MB replaced everything with BEHR even the HE. It was kind of apparent from up top if you looked along the side -there is a part # that is consistent with BEHR and of course when you remove the under tray you will see the sticker. Good Luck!
Old Jul 18, 2008 | 07:47 PM
c32used's Avatar
LET C32 2002
Exclamation
Believe it or not guys I posted a thread with a poll on Valeo and Behr and quite alot(won the poll) had the original Valeo without issues...now I did replace my Valeo cause it was a great deal but I really wasn't to worried before...I guess since I have the warranty I never was worried when it was a valeo.
here is the link: https://mbworld.org/forums/c32-amg-c55-amg-w203/226467-valeo-radiator-behr.html
I know it not alot of votes but the average was without issue with the original Valeo.
The problem is a few post a issue and it seems like all have it also.
Old Jul 19, 2008 | 01:27 AM
pointman's Avatar
here is the link: https://mbworld.org/forums/showthread.php?t=226467
Thanks. That actually made me feel better. I have been debating whether to dump my c32 cause this issue alone. I love the car though.
Old Jul 19, 2008 | 12:55 PM
gnma's Avatar
The E-class, (and others I believe) have suffered from glycol contamination, and they had the Valeo radiators. Guess which years those cars suffered the problem in?...Not trying to scare anyone, but from that poll, 52% had no problems with the original Valeo, but go read that MB bulletin, which acknowledged a flaw in those early Valeos.
Your poll also shows 0% of owners with no problems with the original Valeo. As you state, its "not a lot of votes", and you're right. Search for the word "glycol" and you'll see how many C32 owners had the problem. You only have about 23 reponses. I easily counted 5 owners who had problems within just one thread. Right there is 20% of your total.
To the original poster, I had to choose the E500 due to space requirements, otherwise today, I would be driving a C32, I would just replace the orig. radiator. I've done it on my Supra, I imagine it should be a piece of cake on the MB too. Either way, good luck!
Old Jul 19, 2008 | 02:06 PM
pointman's Avatar
Thanks for the insight. I have a mid 04 build, and should be free of the issue. But my concern is that I had the radiator changed at the dealer, and wonder if its possible a replacement could be a bad one.
Old Jul 19, 2008 | 02:52 PM
c32used's Avatar
LET C32 2002
My thread only show the results of the people who cared to share which obviously not all did. If you want truer percentages then I suggest some take all the complaints and compare them to the amount of the amount of cars created that year and also check the year and model that way its much easier to to get a more accurate percentage of the model and year it effects. As long as warranty is active honestly who cares. If no warranty then change it to be on the safe side. As I stated I changed mine to a Berh just to be safe. But at the same what garranties it will happen? I say if you worry change it.
